No commands work inside reactors. -Basic reactor rules-
You can access variables with (getvar "cannoscale") or (vla-getvariable
"cannoscale")
If that doesn't work, post your code.
wrote in message news:5750059@discussion.autodesk.com...
Does anyone know why the command "cannoscale" does not work in a command reactor? To see
what is happening, I substituted "line" instead and when I use line, the routine fires
correctly. If I replace it with "cannoscale" or even "_cannoscale", nothing happens.
Clues, hints?? In case someone has another way, all I am trying to do is sense that the
Annotation Scale was changed, and by using cannoscalevalue, set a UserR3 variable with
that info. Autocad 2008 specific of course
