Cannoscale in Command Reactor
5 REPLIES 5
338 Views, 5 Replies
Does anyone know why the command "cannoscale" does not work in a command reactor? To see what is happening, I substituted "line" instead and when I use line, the routine fires correctly. If I replace it with "cannoscale" or even "_cannoscale", nothing happens. Clues, hints?? In case someone has another way, all I am trying to do is sense that the Annotation Scale was changed, and by using cannoscalevalue, set a UserR3 variable with that info. Autocad 2008 specific of course
5 REPLIES 5
No commands work inside reactors. -Basic reactor rules-
You can access variables with (getvar "cannoscale") or (vla-getvariable
"cannoscale")
If that doesn't work, post your code.
wrote in message news:5750059@discussion.autodesk.com...
Thanks for the reply Doug. Guess I should watch my words. Its a commandended reator (if thats the proper term to use). The following should indicate what I am doing (and whats not working when I even type in cannoscale)
[code]
(vl-load-com)
(vl-load-reactors)
(vlr-command-reactor
nil
'((:vlr-commandEnded . EndCommand))
nil
'((:vlr-commandCancelled . EndCommand))
(defun EndCommand (calling-reactor endcommandInfo / thecommandend)
(setq thecommandend (nth 0 endcommandInfo))
(cond
((= thecommandend "CANNOSCALE")
(EC:annoscale1)
((= thecommandend "LINE")
(EC:annoscale1)
(defun EC:annoscale1 ()
(if (= 1 (getvar "msltscale"))
(progn
(alert "did it")
(setvar "userr3" (/ 1.0 (getvar "cannoscalevalue")))
) ; end progn
) ; end if
(princ "\nLoaded Temp-command-reactors Routine version 1.0")
[/code]
Cannoscale is a sysvar. Use the sysvar reactor to track it. The commanended reactor
should track the setvar command but it won't give you any info about what sysvar was
changed.
(vlr-sysvar-reactor nil '((:vlr-sysvarchanged . yourcallback)))
wrote in message news:5750203@discussion.autodesk.com...
[code]
(vl-load-com)
(vl-load-reactors)
nil
nil
(cond
(EC:annoscale1)
(EC:annoscale1)
(progn
(alert "did it")
) ; end progn
) ; end if
[/code]
Thank you Doug. I wasn't thinking that it was actually a setvar item.. just kept thinking it was a command. Now it works as required and I can now keep Userr3 in sync with the annotative scale in the drawing. Much appreciated!
You're welcome.
wrote in message news:5750359@discussion.autodesk.com...
”Boost
