Visual LISP, AutoLISP and General Customization
Adding a date stamp to deter.vlx
7 REPLIES 7
Message 1 of 8
1939 Views, 7 Replies
I am a user, but unfortunately not a creator, of lisp routines. I'd like to be able to use the deter routine, but add a function to it whereby a date stamp (similar, I imagine, to a plot stamp but showing the date that the tool was used) would be added at a certain location (bottom right of the display, or at specific coordinates).
Firstly, is this possible? Secondly, would anyone be willing to give me an idea of how I would achieve this? Thanks!
Edited by: CraigPalmer on Mar 5, 2010 7:51 AM Edited by: CraigPalmer on Mar 5, 2010 7:51 AM
7 REPLIES 7
Message 2 of 8
You can not modify a VLX file, it is compiled. The reason the author
compiled it was to protect the contents. You have to contact the author.
HTH
a écrit dans le message de news:
6349429@discussion.autodesk.com...
Message 3 of 8
I see - thanks for the advice. I'll try to track down the author. In the meantime, is there a LISP routine similar to Deter which could be modified?
Message 4 of 8
I don't know, but I think that a search on the web could lead to something.
6349468@discussion.autodesk.com...
Message 5 of 8
But what date do you want to stamp ? What tool are you talking about ? Maybe
the fields in AutoCAD could help you with this, but you should be a little
more specific.
You can have the current date, the document creation date, the last save
date and the printing date.
Message 6 of 8
> whereby a date stamp ...
Why not simply add an annotation object to the drawing before you deter?
Terry
Never start any job without the right tools!
AutoCAD Add-on Tools at http://www.dotsoft.com
Message 7 of 8
I'd want to display the current date, and then run Deter.
I've looked at a couple of old LSPs, but I think I've found a useful macro to use for a date stamp. It would have been useful to be able to run both that and Deter together, but this is better than nothing.
Message 8 of 8
Good point, and this is/was my initial plan. Running a date stamp tool would take just as long as adding text, but a colleague had asked me if it was possible to include the extra feature.
Thanks for deter, by the way!
Forma Design Contest
