I am trying to figure out how to upload an SQL database to Vault (or tables from the database). I have one table with 117,000 fields - each record is related to a drawing. I know that you can create user-defined properties and have them display as columns in Vault Explorer. I would love to be able to upload the complete table into Vault so that it's viewable in the Explorer.
Does anyone have a solution for this?
Sorry but the Vault database is not something you can customize. Both the Autodesk Developer Network and Autodesk Support will provide NO ASSISTANCE to an install with a modified database.
For more information, you can see the "Database Editing" page in the SDK documentation.
The best way to do what you want is to create a user-defined property. Next write a progam to read your table and set the UDP values for each file.
That's exactly what I want to do - I have no intention of modifying the Vault database. I want to be able to look up a historical database of drawing numbers containing customer information and various other drawing data..
I'm not sure what "Bulk Processor" tool you are referring to. I know that Autodesk Consulting has a tool for property import and coolOrange has a product called dataLoader.
Vault 2012 does not have built-in capabilites to do a bulk import of file properties.
Sorry. I should be more specific. The Vault database cannot be modified directly. And by directly, I mean opening up a direct connection to SQL Server and performing queries or operations.
If you make a call through our published API and that call ends up modifying the database, then that is OK. If we didn't want you to do something, we wouldn't have put it in the SDK.
The "Database Editing" page in the SDK documentation goes into more details.
Here is an example of good code:
DocumentService.UpdateFileProperties(...)
Here is an example of bad code:
INSERT INTO VaultProperties (name, value) VALUES ('Author', 'Doug')
