Load to mass conversion
23 REPLIES 23
Message 1 of 24
Refaat
4002 Views, 23 Replies
Dear Sir
-  Which mass type (global mass & dynamic mass ) shall I use it for my model (concrete tower 21 floor )?
Shall I activate the mass in three directions (X,Y,Z) or only (X,Y) Because my building height = 75m ?
 Thanks in advance
Refaat
23 REPLIES 23
Message 2 of 24
in reply to: Refaat
Most accurate is consistent I believe.  But we normally use lumped with rotations.
If you disregard density there will be no mass participating in the modal analysis. Unless you add it back in via load to mass conversion.
I would NOT disregard density, and also add 30% live load (or whatever percentage) to the load to mass conversion.  Normally can ignore Z direction.  If you add mass to global or dynamic the mass will be added to all dynamic cases.  If you specify the modal case only, it will only be added to that case.
Message 3 of 24
Rafal.Gaweda
in reply to: Refaat
Refaat
 http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Conversion-load-to-mass/m-p/3050232/highligh... - message 3
Rafal Gaweda
Message 4 of 24
Refaat
in reply to: Rafal.Gaweda
Dear Sir
I got confused about base shear coeff. ( as i see in the attached capture 01) you got this coeff. (1.74) by dividing (automatic / inactive ). Did you mean that the inactive case is the static linear case ?? (because as we know that the base shear scale is the ratio (0.85Vstatic/Vdyanmic) . as I used it in the capture 02 ,is it true or not ?
Refaat
Message 5 of 24
Refaat
Dear Sir
Pls , give me more explanation (  3 Selecting Global mass - converted masses will be applied to all dynamic cases and also can be used in inertia   forces (of course if such forces are applied on model)
  In my case , I will use (global mass ) in my model is Keya ?
Refaat
Message 6 of 24
Rafal.Gaweda
in reply to: Refaat
Example:
Rafal Gaweda
Message 7 of 24
Rafal.Gaweda
in reply to: Refaat
Refaat,
Inactive means that results come directly from seismic calculation without base shear.
Yes, true.
One more remark: do not use "Use normalized values" checkbox.
Rafal Gaweda
Message 8 of 24
Refaat
Dear Sir
Do you mean that ( Dynamic = globle + modal ) ? , and i have to use dynamic
Rrfaat
Message 9 of 24
Refaat
Dear Sir
As appears in the attached capture
As I understand (T= structure period ) and what  about (reduction coeff.)?
Refaat
Message 10 of 24
Rafal.Gaweda
in reply to: Refaat
Global means that converted masses will be considered in ALL dynamic cases in model (modal and footfall ones; other dynamic cases need to be run after modal case so they consider masses from precedent modal).
My advise: use dynamic.
Rafal Gaweda
Message 11 of 24
Refaat
Dear sir
Confirmation  >>>>>> ((seismic pseudo model(ritz)) with dynamic mass is okay ?
Thanks  a lot
Refaat
Message 12 of 24
Refaat
in reply to: Refaat
Dear Sir
Refaat
Message 13 of 24
Rafal.Gaweda
in reply to: Refaat
Okay
Rafal Gaweda
Message 14 of 24
Refaat
in reply to: Refaat
Dear Sir
Refaat
Message 15 of 24
Rafal.Gaweda
in reply to: Refaat
I need to check the codebook. Wait.
Rafal Gaweda
Message 16 of 24
Refaat
Dear Sir
Could i know if you have checked the code book ? I am waiting .
(UBC97)
Thanks alot
Refaat
Message 17 of 24
Rafal.Gaweda
in reply to: Refaat
(UBC97)
It is just a factor to multiply calculated base shear by it.
Rafal Gaweda
Message 18 of 24
Refaat
Dear Sir
Pls , Could u give me more explanation ?. From where can i get it  and how to calculate it?
Refaat
Message 19 of 24
Refaat
in reply to: Refaat
Dear Sir
Thanks for your help
Refaat
Message 20 of 24
Rafal.Gaweda
in reply to: Refaat
1631.5.4 Reduction of Elastic Response Parameters for design.
Rafal Gaweda
