• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Contributor
    MohammadZaman
    Accepted Solution
    Conversion load to mass
    937 Views, 8 Replies
    06-07-2011 01:44 PM
    Hi dear
    why there is a difference between the modal mass and dynamic mass?
    And one more problem
    the Base shear coefficient that the robot 2011 is calculating is too big , about 2.5 in dynamic mass  or sometimes 0.55 in modal mass  but the real value is  about 0.35
    I have used ubc 97 for applying seismic load.
    V=c.w
    but v didn't calculate from multiply c.w from the value for c and w that the robot 2011 has calculated.
    Please help me
    thank you .
    Please use plain text.
    Moderator
    Romanich
    Re: Conversion load to mass
    06-07-2011 10:37 PM in reply to: MohammadZaman
    I just looked file modal.pdf:
    Product Support
    06-07-2011 11:41 PM in reply to: MohammadZaman
    You can convert loads to masses in 3 ways.
    1 Seecting Modal case
    2 Selecting Dynamic mass - mass will be added to all dynamic cases
    3 Selecting Global mass - converted masses will be applied to all dynamic cases and also can be used in inertia forces (of course if such forces are applied on model)
    PLease check your loads to mass conversion as Romanich suggested. If it is not the case it could be good to upload the file for us to analyze
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Contributor
    MohammadZaman
    06-08-2011 12:13 AM in reply to: RG_Adsk
    Hi
    Thank you for your attention
    I have attached the file
    Product Support
    06-08-2011 01:14 AM in reply to: MohammadZaman
    First of all I sugest to use only one self weight as a mass. There are two such masses in your model: one coming from Modal case definition ("Disregard Density" checkbox), another from Loads to Mass Conversion.
    Converted masses are not used for base shear scaling unless you convert them using  Global Mass or Dynamic Mass.
    After these modifications base shear coeff ~=1.75. I will check the codebook
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Contributor
    MohammadZaman
    06-08-2011 02:20 AM in reply to: RG_Adsk
    Thank you
    Active Contributor
    MohammadZaman
    06-08-2011 03:21 AM in reply to: MohammadZaman
    1.7 is too big
    Product Support
    06-08-2011 04:47 AM in reply to: MohammadZaman
    As far as I can see from the codebook (formula 30-4) you want either to see Cv coeff or C from V(base shear) = C*W(total weight\mass). These values are not presented in program.
    Base shear coeff presented in report is in fact the ratio of base shear calculated with scaling to base shear without scaling.
    See attached screen shot
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Contributor
    MohammadZaman
    06-08-2011 12:54 PM in reply to: RG_Adsk
    Tank you so much
