Setting visibility states (tried setting it for all my 3d views) and/or view settings to fine not working (today) for showing rebar as solids in 3d view. Any idea's what could be the issue?
Solved by PavelAnd. Go to Solution.
Hi @martijn_pater . Is detail level of rebar in visibility/graphics overrides "By View" or "Fine"? It will be better if you can upload the file.
Best regards, Pavel Plotitsyn.
I totally missed that one! It was set to medium by the view template I was using. Resetting it to 'by View' in VG resolved the issue. Thanks!
Hi. I encountered a problem issue show rebar solid while opened " View as solid". i hope to be supported. Thank you
My name is Duc, from Viet Nam
