Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Solid rebar in 3d View
4 REPLIES 4
martijn_pater
965 Views, 4 Replies
Setting visibility states (tried setting it for all my 3d views) and/or view settings to fine not working (today) for showing rebar as solids in 3d view. Any idea's what could be the issue?
4 REPLIES 4
PavelAnd
in reply to: martijn_pater
Hi @martijn_pater . Is detail level of rebar in visibility/graphics overrides "By View" or "Fine"? It will be better if you can upload the file.
Best regards, Pavel Plotitsyn.
martijn_pater
in reply to: PavelAnd
I totally missed that one! It was set to medium by the view template I was using. Resetting it to 'by View' in VG resolved the issue. Thanks!
vuducutc_1209
Hi.  I encountered a problem issue show rebar solid while opened " View as solid". i hope to be supported. Thank you
My name is Duc, from Viet Nam
You need to tick the Box for 3D Copy 1 as that is the View Referenced in the image
Jay Colcombe
Autodesk Certified Instructor
Autodesk Customer Advisory Groups
