Revit MEP Forum
Hatching for duct insulation
9 REPLIES 9
Message 1 of 10
3231 Views, 9 Replies
I'd like to make it so when I add insulation to a duct, it shows up as a hatch. Also, when I add a different thickness (i.e 1" or 2") it would show up as a different hatch. Is this possible?
9 REPLIES 9
Message 2 of 10
I've tried to make a filter based on the insulation thickness as shown in the picture below. But when I hit apply, it still doesn't hatch the ducts
Message 3 of 10
bvm76
I believed you can find both of your queries from previous post. Try to search the community.
Please mark Accept as Solution if your question is answered!
Thank You.
Message 4 of 10
in reply to: bvm76
The only other posts I found were advising me to use filters. I have tried this to not avail
Message 5 of 10
CoreyDaun
The "equal to" operator may be "malfunctioning". I can reproduce this in an imperial Project with Duct Insulation of 1" and a filter that specifically targets that thickness; the Duct Insulation remains unaffected. Try changing the Filter Rules to:
"Insulation Thickness" "is greater than or equal to" "39.99 mm"
 -- and --
"Insulation Thickness" "is less than or equal to" "40.01 mm"
If this is the case, I would suggest reporting this behavior to the Autodesk Revit Development Team using the link below:
Autodesk Product Support
The following link is setup for you to submit feature requests, or feedback, directly to our Development group:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Message 6 of 10
in reply to: CoreyDaun
This worked for the 25mm insulation, in some instances, but not for every duct with insulation. It didn't work at all for any duct with the 50mm insulation.. Any ideas? I'm using the 1.5mm diagonal hatch for the 25mm and the 1.5 mm diagonal cross for the 50mm.
Message 7 of 10
bvm76
make sure the duct insulation is switch off under visibility graphics.
i tried the 1.5mm diagonal cross hatch and it works. try to change from 25mm to 50mm if it refresh.
Thank You.
Message 8 of 10
in reply to: bvm76
That did the trick!
Message 9 of 10
Sujan.Maharjan
in reply to: bvm76
Hatch is visible but i need to show insulation line as well?
"Revit Lies in the tension between what we want to do and what can be done!"
Message 10 of 10
Add insulation. Make filter to control hatching of insulation.
