2D PDF printing support
Not exactly an original idea, but provide a built-in PDF printer
107 Comments
I do not understand why this is top voted?..
2d printing is more and more the past..is my opinion
forenow there is still printing aquired
I can think of beter ideas already posted..
dplumb_BWBR
Different things are important to different people.
If there are other ideas more important to you, feel free to upgrade them.
That's kind of the point of this voting system.
sasha.crotty
We have adjusted the title and contents of this idea to reflect the functionality under review by the Revit team. Check out the separate ideas for PDF linking and 3D PDF if you are interested. Thanks for voting!
Is it possible  to added a standard pdf printer to Revit, as in Autocad.
adrian.calabria
Agree. Also having to click save for every sheet is quite painful
c.barribaud
We never only have ONE paper size for all of project sheets.
So PLEASE make paper size configuration by sheet not by project !!
chris.cromer
Great idea!  And it seems like this issue is "Under Review" by Autodesk already, see this Idea post:  http://forums.autodesk.com/t5/revit-ideas/2d-pdf-printing-support/idi-p/6325091
It is definitely horrible need to dowload a pdf creator plug in to plot something at REVIT
At AUTOCAD it was very easy, because already have a model to plot as .pdf.
I am definitely very sab about it.
Simon_Weel
dbroad
Agree here. There should be consistency.  I have Adobe Acrobat so this doesn't affect me but is would affect many others.
Some city halls ask for PDFs with layers, to control visibility. Revit don't do that, so we have to do those projects in autocad and not Revit. Big handicap.
As this idea is not exactly what I have in mind but it's pretty close I will comment here. The problem is that up to now most clients want PDF files for their archive or whatever. Revit requires each sheet to be opened and than execute the print command and type the filename. This is far too complicated....
The idea I just posted is about "exporting" to Revit in order to export all selected sheets with the Revit view name in one command, like it does for DWG. This is a big time saver.
It would be great if you could read my idea, comment on it and/or vote for it.
cheers
wolfgang
Zentraplan
Yes, 2D PDF is very important and 3D PDF would be also very nice and helpful
I would be helpful to give naming settings to exported pdf files like the bullzip printer.
Maybe with the project parameters: <Date>_<Project Number>_<Sheet Number>_<Sheet Name>
170220_W-17-0000_SO-01_Plan.pdf
Already mentioned but the pdf printer has to be able sort on print size and print various sizes by each other.
filipefrancisco
Yes good suggestion
eric_doan
A built-in PDF printer would be awesome!
Plus, API support similar to what we have for DWG export would be perfect. Direct control over output file name and location will be a huge time saver.
document.export (folder, name, views, PDF export options)
And please, make it so that sheet lists are actual hyperlinks! (just like call out and section bubbles are)
lionel.kai
@pieterschiettecatte I suspect that Autodesk will want that as a separate idea thread (since including a built-in PDF printer, and changing WHAT gets sent to it - or any PDF printer, are two different things), so could you create one & link to it here? That way we can vote on it, too.
aleksei.melnikov
It would be great if The New Revit PDF Export could export lines thinner than 0.085mm (0.003 in) because such limitations are useless, now it cause many differences between what you see in Revit and what you print.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
aleksei.melnikov
Now printed PDF looks different from the revit viewport because of thickness limitation
(sorry for the duplicating)
