I wish to change the oanel lengths in the generic door family so as to have one panel which is smaller than the other rather than both panels having equal lengths.
Solved by barthbradley. Go to Solution.
Revit has one in the OOTB Content Library. Door-Passage-Uneven-Flush.rfa. Under Doors\Commercial.
Is it possible for you to share the said family, asm y library is pretty messed up will trying looking for it on the net as well. Also tysm
To change how parts of the family are displayed in various views you can open up the family editor, select an element(door, frame, trim, etc...) then open the visibility settings for that element
