Hatch from DWG in .rfa not showing properly in .rvt
6 REPLIES 6
vladislavs.aleksandrovsWFY88
552 Views, 6 Replies
Hi all,
I am trying to solve an issue with a AutoCAD hatch not showing properly in the Revit project.
In the title block template I have company logo in .dwg format, all letters are created via hatch. It shows properly in the .rfa, but whenever I upload the template to the project, hatch fills out letters completely (refer to the attached image).
If I upload the logo directly to the project, it shows properly, not filling any gaps.
I would appreciate any thoughts or help.
Labels (2)
6 REPLIES 6
Make it with native Revit filled regions.
Did you try exploding .dwg file in Titleblock.
Also, sometimes it helps if the logo (.png, .dwg) is not in the Group inside the Titleblock family.
Scale the DWG in AutoCAD like 10x. Import it in a the Revit family and scale it down 0.1x.
If only it would be that easy. Unfortunately, due to Revit line length restrictions of 0.8mm I cannot draw a region that can be scaled to smaller size if required.
Yes, I tried. Revit tries to draw the hatch with lines which leads it to delete everything in case there is a line shorter than 0.8mm.
Unfortunately, it didn't work.
Forma Design Contest
