You cannot rotate a system based wall (the walls you get when pressing the
Wall tool) in elevation, or rotatate it off Z-axis.
You can edit the profile of a linear wall by selecting the wall and pressing
"Edit Profile" in the option bar. Once in the sketch, you can pretty much
draw whatever you want (a 45 degree angle if you prefer) and the wall will
reflect the sketch.
For the arc wall, I would draw a ref-plane at desired angle, and then
"Attach" the wall to the ref-plane. You can attach top and bottom of walls
to ref-planes
For a wall that is tilted off the z-axis, you will have to engage the
in-place family tools.
"mthemelis" wrote in message
news:20569792.1091908788490.JavaMail.jive@jiveforum1.autodesk.com...
> How can i rotate a wall in the elevation, or create it in an angle of 45
degrees to the ground?
> In arc walls how can i chanfe the profile?
