Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
is family instance joined?
5 REPLIES 5
russ.green
928 Views, 5 Replies
I can't see anything using RevitLookup but is there a way to tell if a family instance has been joined to something?
When tranforming an edge I'm getting different results after joining the family to another family or a wall, etc.
Russ Green
5 REPLIES 5
rosalesduquej
in reply to: russ.green
Dear Russ,
Hi, I raised the question to our engineering team, and here is the response from one of them.
I think there are a couple of things to try:
1.) JoinGeometryUtils.GetJoinedElements()
For this one you could check out the post on Jeremy Tammik blog: http://thebuildingcoder.typepad.com/blog/2014/02/getting-two-different-kinds-of-joined-elements.html
2.) For concrete framing family instances and walls, you can get the Element’s Location, cast to LocationCurve, and look at ElementsAtJoin.
And for this 2nd suggestion you can look at this link. http://thebuildingcoder.typepad.com/blog/transaction/page/2/ Look for the post with title Wall Joins and Geometry.
There is also Element.GetGeneratingElementIds() which tells you for a given piece of geometry from an element what element causes this geometry to form.
Let us know how it goes, enjoy.
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
russ.green
in reply to: rosalesduquej
The first method worked for me.
Russ Green
can you show me JoinGeometryUtils.JoinGeometry method?
russ.green
You get the joined elements something like this
Dim the_list_of_the_joined As ICollection(Of ElementId) = JoinGeometryUtils.GetJoinedElements(document, familyinstance)
You can then check the size of the ICollection or projecess the elements stored in it.
Russ Green
thank you so much, i'm beginer in revit api should I'll need your help any
more.
Forma Design Contest
Rail Community
