ObjectARX
There is a debug in ObjectArx 2011 or AutoCAD 2011 ?
3 REPLIES 3
1032 Views, 3 Replies
When I unload my arx application in AutoCAD 2011,I get a problem.
That is my command and my group which I load into AutoCAD 2011 through my arx application
can not be unload.So when I load the arx application again.The AutoCAD 2011 will abort
Please tell me how can get rid of the debug .
3 REPLIES 3
Are you calling acrxLockApplication() or acrxDynamicLinker->lockApplication() before your commands run?  If so, you need to call acrxUnlockApplication() when they finish.  Otherwise, you will not be able to unload your app.
Joe
I got the same error when i try to upload my arx apps on autocad
Edited by
Discussion_Admin
There is my code. and these codes are created by ObjectArx Wizard.
#define szRDS _RXST("wy")
//----- ObjectARX EntryPoint
class Cwyarx01App : public AcRxArxApp {
public:
 Cwyarx01App () : AcRxArxApp () {}
 virtual AcRx::AppRetCode On_kInitAppMsg (void *pkt) {
  // TODO: Load dependencies here
  // You *must* call On_kInitAppMsg here
  AcRx::AppRetCode retCode =AcRxArxApp::On_kInitAppMsg (pkt) ;
  // TODO: Add your initialization code here
  return (retCode) ;
 virtual AcRx::AppRetCode On_kUnloadAppMsg (void *pkt) {
  // TODO: Add your code here
  // You *must* call On_kUnloadAppMsg here
  AcRx::AppRetCode retCode =AcRxArxApp::On_kUnloadAppMsg (pkt) ;
  // TODO: Unload dependencies here
  return (retCode) ;
”Boost
