I am having a problem using the intersectWith function to return an intersection between a circle and line, both of which are AcGe class objects. Can someone please point me in the right direction? The relevant code is below. Also, any pointers on anything else that is done incorrectly would be appreciated. I am trying to basically draw a circle, then draw a leader from the center to a chosen point, then finally draw two lines starting at the leader tip back to the circle, 90 degrees around to each side from where the leader intersects it. The problem is that it does not find any intersection points and draws instead to the origin.
TIA,
Ralph
// Create the circle double const Pi = 3.14159265358979; AcGePoint3d centerPt; // center point of brace circle AcDbCircle* pBraceCircle; // pointer to brace circle if(acedGetPoint(NULL, _T("\nSpecify brace point on roof: "), asDblArray(centerPt))) { float radius(4.5); // circle radius pBraceCircle = new AcDbCircle(centerPt, AcGeVector3d::kZAxis, radius); // Add the circle to database and close it addToModelSpace(pBraceCircle); pBraceCircle->close(); } // Create the leader AcGePoint3d supportPt; // point on wall or beam if(acedGetPoint(asDblArray(centerPt), _T("\nSpecify support point for brace: "), asDblArray(supportPt))) { AcDbLeader* pLeader = new AcDbLeader(); // add the leader to database and then close it addToModelSpace(pLeader); pLeader->appendVertex(supportPt); pLeader->appendVertex(centerPt); pLeader->close(); } // Create the lines connecting the leader tip to the circle sides // convert the 3d points at brace and support points to 2d AcGePoint2d supportPt2d(supportPt.x, supportPt.y); AcGePoint2d centerPt2d(centerPt.x, centerPt.y); // get a construction line in direction of leader and rotate 90 degrees AcGeLineSeg2d geBraceLine(supportPt2d, centerPt2d); AcGeLine2d gePerpLine; geBraceLine.getPerpLine(supportPt2d, gePerpLine); gePerpLine.rotateBy(Pi/2, centerPt2d); // get a construction circle over brace circle // find intersections with construction circle and line AcGeCircArc2d geBraceCircle(centerPt2d, 4.5); int intN; // number of intersections AcGePoint2d intersPt1, intersPt2; // intersecting points geBraceCircle.intersectWith(gePerpLine, intN, intersPt1, intersPt2); // create the first line, add to database and close AcGePoint3d StartPt1( intersPt1.x, intersPt1.y, 0); AcDbLine* pBraceLine1 = new AcDbLine(StartPt1, supportPt); addToModelSpace(pBraceLine1); pBraceLine1->close(); // create the second line, add to database and close AcGePoint3d StartPt2( intersPt2.x, intersPt2.y, 0); AcDbLine* pBraceLine2 = new AcDbLine(StartPt2, supportPt); addToModelSpace(pBraceLine2); pBraceLine2->close();
Is this line neccessary "geBraceLine.getPerpLine(supportPt2d, gePerpLine)"? Could it leave the line outside the circle?
Try some version of the following it may be easier to debug.
AcDbLine geBraceLine(AcGePoint3d(-2,0,0), AcGePoint3d(2,0,0));
AcGeMatrix3d xform1;
xform1.setToRotation(UtilsGe::kRad90, AcGeVector3d::kZAxis, AcGePoint3d(0,0,0));
geBraceLine.transformBy(xform1);
AcGePoint3d startPt = geBraceLine.startPoint();
AcGePoint3d endPt = geBraceLine.endPoint();
AcDbLine gePerpLine(startPt, endPt);
AcDbCircle geBraceCircle(AcGePoint3d(0,0,0),AcGeVector3d::kZAxis, 1);
AcGePoint3dArray points;
geBraceCircle.intersectWith(&gePerpLine, AcDb::kOnBothOperands, points);
for(int i=0; i<points.length(); i++)
CString str;
ptToStr(points[i], str);
acutPrintf(L"\n %s", str);
Shane.
Thank you both for the replies. Shane, I used the AcDb lines instead of the AcGe ones and that seemed to correct the issue. I guess I'll have to play around with the AcGe objects for a while before I understand them. I can't seem to get anything useful out of the debugger - just hexadecimal information. I am interested in the ptToStr function you called, though. I don't seem to have that one. Is that something "new"? (I'm still on AutoCAD 2008 until I get all of my old VBA code updated.)
Thanks again,
Ralph
Ralph,
Have a look at the ARXDBG project in samples/database. You will find ptToStr in ArxDbgUtils.h along with a great deal other useful functions. If you import ArxDbgUtils into your project it will simplify many common tasks. Also I find the ArxDbgUiPr... classes very useful for simplifying user interaction.
Shane.
I use objectarx2012, cad 2012. i've tesed intersectWith function. Here's code :
static void Test(void){
AcDbObjectId oId;
AcArray<AcGePoint3d> IntersectionPoints;
ads_name name1, name2; AcDbEntity *pEnt1,*pEnt2;
acedEntSel(L"\nSelect Ent1(line1 😞 ",name1,pt); acdbGetObjectId(oId, name1); acdbOpenAcDbEntity(pEnt1,oId,AcDb::kForRead);
acedEntSel(L"\nSelect Ent2(line1 😞 ",name2,pt); acdbGetObjectId(oId, name2); acdbOpenAcDbEntity(pEnt2,oId,AcDb::kForRead);
pEnt1->intersectWith(pEnt2,AcDb::kOnBothOperands ,AcGePlane::kXYPlane, IntersectionPoints, 0,0 ); //May be this line cause error!
pEnt1->close(); pEnt2->close();
// // Autocad crashed when go out this
Autocad crashed when Test ended.
Can AnyOne help me?
Thank advance.
Please start a new thread, and include more information. "AutoCAD crashed" is not enough detail.
