Hello group,
I am updating about a dozen arx applications for ACAD2013 using VS2010. I have successfully updated all but one. The complier settings are the same for all projects but the troublesome one generates the error shown in the subject when loaded. I have tried to force the use of the non "D" library and the linker is set to use /MD not /MDd. A curious thing happens during the compile process, a few source files are compiled then a new cl.exe line shows up and the rest of the source files are compiled. I suppose that could just be the multiprocessing mechanism. Build log attched.
Thanks in advance
Martin Miler
Mayers and Associates Civil Engeering, Inc.
Solved by owenwengerd. Go to Solution.
How did you try to force use of the release library?
Property page Linker->Command Line->Additional Options: /DEFAULTLIB:"MSVCRT"
That got it load without AutoCAD complaining, however none of the dialogs will start. I'll keep digging. Thanks for your help Owen, here and throughout this group.
MM
Whatever is pulling in the debug library still needs to be addressed. I would use the /verbose linker option to see where it's coming from. Thanks for the kind words.
Final Resolution:
I created a new project from an MFC sample and copied in my existing code.
MM
