I am able to access(list & modify) custom sheet properties within a sheet set via .GetCustomPropertyBag. How are the OOTB sheet properties accessed? Could someone point me in the right direction?
Thanks.
Chris
Hi Chris,
Do you mean adding the custom properties to a sheet instead of a sheetset ?
If that is the case, it is very similar to the way the custom properties were added to the sheetset.
Here is a sample code :
Private Sub SetSheetCustomProp() Dim doc As Document doc = Application.DocumentManager.MdiActiveDocument Dim ed As Autodesk.AutoCAD.EditorInput.Editor ed = doc.Editor sheetSetMgr = New AcSmSheetSetMgr Dim iterDb As IAcSmEnumDatabase iterDb = sheetSetMgr.GetDatabaseEnumerator Dim ItemDb As IAcSmPersist ItemDb = iterDb.Next sheetdb = ItemDb LockDatabase() Dim sheetsetEnum As IAcSmEnumComponent sheetsetEnum = sheetdb.GetSheetSet().GetSheetEnumerator() Dim sheetsetItem As IAcSmComponent sheetsetItem = sheetsetEnum.Next() Dim iterator As IAcSmEnumPersist iterator = sheetdb.GetEnumerator() Dim item As IAcSmPersist item = iterator.Next() While item IsNot Nothing Dim type As String type = item.GetTypeName() Select Case type Case "AcSmSheet" 'List the sheet Dim sheet As IAcSmSheet = TryCast(item, IAcSmSheet) Dim i As Integer i = 0 Do While i < 5 Dim cBag As IAcSmCustomPropertyBag Dim cBagVal As New AcSmCustomPropertyValue cBag = sheet.GetCustomPropertyBag cBagVal.InitNew(cBag) cBagVal.SetFlags(PropertyFlags.CUSTOM_SHEET_PROP) cBagVal.SetValue("Test" + i.ToString()) cBag.SetProperty("Test" + i.ToString(), cBagVal) cBagVal = Nothing i = i + 1 Loop Case Else ed.WriteMessage("vbCrLfType :" + type) End Select item = iterator.Next() End While UnlockDatabase() End Sub
Thanks for the response and code. I was hoping to access the non-custom properties of a sheet like:
Sheet title, Sheet number, Revision number, Revision date, Purpose, Category, Description & Include for publish
I know I can do this through SSM but can I access progrmatically?
Thanks.
Chris
Hi Chris,
Here is a blog post on accessing these properties :
Thanks! I now see how I can loop through sheets and get the current values. I would now like to modify these values, I noticed the following methods: .SetRevisionNumber, .SetRevisionDate, .SetIssuePurpose and .SetCategory. I tried to update using these methods ( example: mySheet2.SetRevisionNumber("2") ) but got an error. How are these values modified? Thanks again.
Chris
Hi Chris,
What is the error message that you get ? Maybe you havent locked the sheetset database before setting the revision number ?
Here is a sample code to set the revision number for all the sheets in a sheetset :
<CommandMethod("SetRevision")> _ Public Sub SetRevisionMethod() Dim dstFile As String dstFile = "C:\Temp\MySheetSet\MySheetSet.dst" Dim mgr As AcSmSheetSetMgr = New AcSmSheetSetMgr() Dim db As AcSmDatabase = New AcSmDatabase() db = mgr.OpenDatabase(dstFile, False) Dim lockStatus As AcSmLockStatus lockStatus = db.GetLockStatus If lockStatus = 0 Then db.LockDb(db) End If Dim ss As AcSmSheetSet = db.GetSheetSet() Dim EnumSheets As IAcSmEnumComponent = ss.GetSheetEnumerator() Dim smComponent As IAcSmComponent Dim sheet As IAcSmSheet Dim sheet2 As IAcSmSheet2 smComponent = EnumSheets.Next() While True If smComponent Is Nothing Then Exit While End If sheet = TryCast(smComponent, IAcSmSheet) ' To access the revision number, ' Revision date, Purpose and Category, ' cast it as IAcSmSheet2 sheet2 = TryCast(smComponent, IAcSmSheet2) If sheet2 IsNot Nothing Then sheet2.SetRevisionNumber("111") End If smComponent = EnumSheets.Next() End While db.UnlockDb(db) mgr.Close(db) End Sub
