.NET
Sheet Set: Access Sheet Properties
6 REPLIES 6
ChrisPicklesimer
788 Views, 6 Replies
I am able to access(list & modify) custom sheet properties within a sheet set via .GetCustomPropertyBag.  How are the OOTB sheet properties accessed?  Could someone point me in the right direction?
Thanks.
Chris
6 REPLIES 6
Hi Chris,
Do you mean adding the custom properties to a sheet instead of a sheetset ?
If that is the case, it is very similar to the way the custom properties were added to the sheetset.
Here is a sample code :
    Private Sub SetSheetCustomProp()
        Dim doc As Document
        doc = Application.DocumentManager.MdiActiveDocument
        Dim ed As Autodesk.AutoCAD.EditorInput.Editor
        ed = doc.Editor
        sheetSetMgr = New AcSmSheetSetMgr
        Dim iterDb As IAcSmEnumDatabase
        iterDb = sheetSetMgr.GetDatabaseEnumerator
        Dim ItemDb As IAcSmPersist
        ItemDb = iterDb.Next
        sheetdb = ItemDb
        LockDatabase()
        Dim sheetsetEnum As IAcSmEnumComponent
        sheetsetEnum = sheetdb.GetSheetSet().GetSheetEnumerator()
        Dim sheetsetItem As IAcSmComponent
        sheetsetItem = sheetsetEnum.Next()
        Dim iterator As IAcSmEnumPersist
        iterator = sheetdb.GetEnumerator()
        Dim item As IAcSmPersist
        item = iterator.Next()
        While item IsNot Nothing
            Dim type As String
            type = item.GetTypeName()
            Select Case type
                Case "AcSmSheet"
                    'List the sheet
                    Dim sheet As IAcSmSheet = TryCast(item, IAcSmSheet)
                    Dim i As Integer
                    i = 0
                    Do While i < 5
                        Dim cBag As IAcSmCustomPropertyBag
                        Dim cBagVal As New AcSmCustomPropertyValue
                        cBag = sheet.GetCustomPropertyBag
                        cBagVal.InitNew(cBag)
                        cBagVal.SetFlags(PropertyFlags.CUSTOM_SHEET_PROP)
                        cBagVal.SetValue("Test" + i.ToString())
                        cBag.SetProperty("Test" + i.ToString(), cBagVal)
                        cBagVal = Nothing
                        i = i + 1
                    Loop
                Case Else
                    ed.WriteMessage("vbCrLfType :" + type)
            End Select
        End While
        UnlockDatabase()
    End Sub
Balaji
Developer Technical Services
Autodesk Developer Network
Thanks for the response and code.  I was hoping to access the non-custom properties of a sheet like:
Sheet title, Sheet number, Revision number, Revision date, Purpose, Category, Description & Include for publish
I know I can do this through SSM but can I access progrmatically?
Thanks.
Chris
Hi Chris,
Here is a blog post on accessing these properties :
http://adndevblog.typepad.com/autocad/2013/01/accessing-revision-number-revision-date-purpose-and-ca...
Balaji
Thanks!  I now see how I can loop through sheets and get the current values.  I would now like to modify these values,  I noticed the following methods: .SetRevisionNumber,  .SetRevisionDate, .SetIssuePurpose and .SetCategory.  I tried to update using these methods ( example: mySheet2.SetRevisionNumber("2")  )  but got an error. How are these values modified?  Thanks again.
Chris
Hi Chris,
What is the error message that you get ? Maybe you havent locked the sheetset database before setting the revision number ?
Here is a sample code to set the revision number for all the sheets in a sheetset :
    <CommandMethod("SetRevision")> _
    Public Sub SetRevisionMethod()
        Dim dstFile As String
        dstFile = "C:\Temp\MySheetSet\MySheetSet.dst"
        Dim mgr As AcSmSheetSetMgr = New AcSmSheetSetMgr()
        Dim db As AcSmDatabase = New AcSmDatabase()
        db = mgr.OpenDatabase(dstFile, False)
        Dim lockStatus As AcSmLockStatus
        lockStatus = db.GetLockStatus
        If lockStatus = 0 Then
            db.LockDb(db)
        End If
        Dim ss As AcSmSheetSet = db.GetSheetSet()
        Dim EnumSheets As IAcSmEnumComponent = ss.GetSheetEnumerator()
        Dim smComponent As IAcSmComponent
        Dim sheet2 As IAcSmSheet2
        smComponent = EnumSheets.Next()
        While True
            If smComponent Is Nothing Then
                Exit While
            End If
            sheet = TryCast(smComponent, IAcSmSheet)
            ' To access the revision number,
            ' Revision date, Purpose and Category,
            ' cast it as IAcSmSheet2
            sheet2 = TryCast(smComponent, IAcSmSheet2)
            If sheet2 IsNot Nothing Then
                sheet2.SetRevisionNumber("111")
            End If
        End While
        db.UnlockDb(db)
        mgr.Close(db)
    End Sub
Balaji
Thanks, I'll give that a try.
”Boost
