Does anybody know away to save the drawing and not lose the thumbnail preview.
Try this before saving the DWG database to a file:
Document doc = Application.DocumentManager.MdiActiveDocument;
doc.Database.ThumbnailBitmap = doc.CapturePreviewImage(320, 240);
-Khoa
Dim doc As Autodesk.AutoCAD.ApplicationServices.Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument doc.Database.ThumbnailBitmap = doc.CapturePreviewImage(320, 240) doc.Database.SaveAs(doc.Database.Filename, True, DwgVersion.Current, doc.Database.SecurityParameters)
Just tried this and it didn't work. This is funny issue.
I tried the following command to save the current thumbnail of an opened drawing and it works for me. When you re-open this drawing, you will see its new updated thumbnail on the AutoCAD Open Dialog.
[CommandMethod("SaveThumbnail")]
public static void SaveThumbnail()
Database db = doc.Database;
db.ThumbnailBitmap = doc.CapturePreviewImage(320, 240);
db.SaveAs(db.Filename, DwgVersion.Current);
-Khoa
I tried that and that don't work. Does 2011 have anything to do with it?
My using AutoCAD version is 2009. We may need other people in the forum to test out this code, to see if it can update the drawing thumbnail based on the current view on AutoCAD.
-Khoa
Try using Database.RetainOriginalThumbnailBitmap to preserve preview.
Facebook | Twitter | LinkedIn
I've tried that some years ago with pure ObjectARX (not AutoCAD .NET API):
AcDbDatabase *pDB = new AcDbDatabase(Adesk::kFalse, Adesk::kTrue); if (pDB->readDwgFile(filePath) == Acad::eOk) { // Some actions with Database pDB->setRetainOriginalThumbnailBitmap(true); pDB->saveAs(filePath); }
Also with C#: http://through-the-interface.typepad.com/through_the_interface/2007/08/purging-regis-1.html
I'm not sure if this is what you want...type op(option) on the command line. click open and save. click thumbnail preview setting and check SAE A THUMBNAIL PREVIEW IMAGE.
Thanks, but that's not what I'm looking for. It's a bug I think in 2011 from the save API. that doesn't save the preview when you call the save API.
The SaveAs() API has never saved the thumbnail preview. It's not a bug.
The solutions that have been posted work, as far as I know, on all releases, except for one, where the CaptureThumbnail API was crashing AutoCAD, but I don't think that bug exists in 2011, otherwise you would have hit it.
I
Hi Michael,
Can you please post the code that you are using ?
Your last reply is a bit confusing :
"I've tried this code on 2011 with DwgVersion.AC1021 and it never seem to save the thumbnail.
But, it work if I use AC1021"
I tried the following code in AutoCAD 2011 and it worked ok. Is it different from the one that you are trying ?
[CommandMethod("Test")] public void commandMethod1() { Document activeDoc = Application.DocumentManager.MdiActiveDocument; Database db = activeDoc.Database; db.ThumbnailBitmap = activeDoc.CapturePreviewImage(320, 240); db.SaveAs("C:\\Temp\\Test.dwg", DwgVersion.AC1021); }
Hello Michael,
I tried saving the drawing as AC1024 and it worked ok in AutoCAD 2011. Also I had no issues in getting the saved images when batch processing of the drawings. Here are the two commands that I am using to test this. Can you run the "_vernum" command and see if it returns "E.208.0.0 (UNICODE)" ?
[CommandMethod("Test")] public void commandMethod1() { Document activeDoc = Application.DocumentManager.MdiActiveDocument; Database db = activeDoc.Database; db.ThumbnailBitmap = activeDoc.CapturePreviewImage(320, 240); db.SaveAs("C:\\Temp\\Test.dwg", DwgVersion.AC1024); } [CommandMethod("Test1", CommandFlags.Session)] public void commandMethod11() { DirectoryInfo di = new DirectoryInfo(@"C:\Temp"); FileInfo[] files = di.GetFiles("*.dwg"); foreach(FileInfo fi in files) { Document doc = Application.DocumentManager.Open(fi.FullName, false); doc.Database.ThumbnailBitmap = doc.CapturePreviewImage(320, 240); doc.Database.SaveAs(fi.FullName, true, DwgVersion.AC1021, doc.Database.SecurityParameters); } }
The background color of the modelspace is used as the back color of the preview image and for this reason, the preview appears partially white. Changing the background color of model space to white and generating the preview image will result in a preview image with fully white background. There is no other way to control the background color.
I finally figured it out. My drawing variable was set on openpartial = 1. Switched to 0 and now works.
