at multiple places i have drawn the same block in a drawing, and i would like select one block in the drawing, then iterate through the items in the block, and find the actual coordinates of a 3d-polyline (that is drawn in that block) in modelspace. How can I do this?
kind regards,
Wouter de Haan
the Netherlands
Solved by Hallex. Go to Solution.
Take a look at GetNestedEntity method of Document Editor
What is the language you prefer C# / VB.NET?
~'J'~
for your currentlyy opened DWG:
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MDIActiveDocument.Editor
- alfred -
Here you go, tested on A2009 only
{code}
Public Shared Function GetAllVertices(ent As Polyline) As Point3dCollection
Dim points As New Point3dCollection()
Dim pt As New Point3d()
Dim i As Integer = 0
For i = 0 To ent.NumberOfVertices - 1
pt = ent.GetPoint3dAt(i)
points.Add(pt)
Next
Return points
End Function
<CommandMethod("Gnp")> _
Public Shared Sub TestSubEntity()
Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Dim ed As Editor = doc.Editor
Dim ucs As Matrix3d = ed.CurrentUserCoordinateSystem
Dim tr As Transaction = db.TransactionManager.StartTransaction()
Try
Using tr
Dim pno As New PromptNestedEntityOptions(vbLf & "Select Nested Polyline >>")
pno.AllowNone = False
Dim rs As PromptNestedEntityResult = ed.GetNestedEntity(pno)
If rs.Status <> PromptStatus.OK Then
Return
End If
Dim entId As ObjectId = rs.ObjectId
Dim selent As Entity = TryCast(tr.GetObject(entId, OpenMode.ForWrite), Entity)
Dim ids As ObjectId() = rs.GetContainers()
Dim blkId As ObjectId = ids(0)
If blkId.IsNull Then
Return
End If
Dim blkEnt As Entity = TryCast(tr.GetObject(blkId, OpenMode.ForRead), Entity)
If blkEnt Is Nothing Then
Return
End If
Dim bref As BlockReference = TryCast(blkEnt, BlockReference)
If bref Is Nothing Then
Return
End If
Dim mat As Matrix3d = bref.BlockTransform
Dim btrec As BlockTableRecord = TryCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
Dim pline As Polyline = TryCast(selent, Polyline)
If pline Is Nothing Then
Return
End If
Dim circ As Circle
Dim points As Point3dCollection = GetAllVertices(pline)
For i As Integer = 0 To points.Count - 1
Dim p As Point3d = points(i)
circ = New Circle(p.TransformBy(mat), Vector3d.ZAxis, 0.1)
btrec.AppendEntity(circ)
tr.AddNewlyCreatedDBObject(circ, True)
Next
tr.Commit()
End Using
Catch ex As Autodesk.AutoCAD.Runtime.Exception
ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
Finally
End Try
End Sub
{code}
~'J'~
In addition, i have another question.
i want to make an adjustment to the supplied code, and therefore i need to step through all objects in the block, but since i am new to .net i cannot get it to work. How can i step through all the objects in the selected block?
Wouter
Wouter,
Here ya go
This crappy code of mine is based on Tony Tanzillo's idea that I did find on this forum
ss give that a try
{code}
_______________________________________
<CommandMethod("GAS")> _
Public Shared Sub GetAllSubentitiesTest()
Dim sb As New StringBuilder
Try
Dim pso As New PromptEntityOptions(vbCr & "Select a Block Reference: ")
pso.SetRejectMessage(vbLf & " Select a Block Reference only!")
pso.AddAllowedClass(GetType(BlockReference), False)
Dim psr As PromptEntityResult = ed.GetEntity(pso)
If psr.Status <> PromptStatus.OK Then
Return
End If
Using tr As Transaction = db.TransactionManager.StartTransaction
Dim ent As Entity = DirectCast(tr.GetObject(psr.ObjectId, OpenMode.ForRead), Entity)
Dim bref As BlockReference = DirectCast(ent, BlockReference)
Return
Else
bref.UpgradeOpen()
End If
Dim btr As BlockTableRecord = TryCast(tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead, False), BlockTableRecord)
If btr Is Nothing Then
Return
End If
Dim expIds As New DBObjectCollection
bref.Explode(expIds)
If expIds.Count > 0 Then
For i As Integer = 0 To expIds.Count - 1
Dim obj As Entity = TryCast(expIds(i), Entity)
If obj IsNot Nothing Then
If Not obj.IsWriteEnabled Then
obj.UpgradeOpen()
obj.TransformBy(bref.BlockTransform) '<-- to get right geometric properties
End If
sb.AppendLine(String.Format("{0}" + vbTab + "{1}" + vbLf, obj.GetRXClass().Name, obj.GetRXClass().DxfName))
obj.Dispose()
End If
Next
End If
bref.DowngradeOpen()
End Using
Catch ex As System.Exception
Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message & vbCr & ex.StackTrace)
Finally
If sb.ToString <> String.Empty Then
MsgBox(sb.ToString)
End If
End Try
End Sub
{code}
~'J'~
