Alex - The CUI interface is an exception.
It has no dependence on AutoCAD and was designed
that way so that it could be use for installation.
Unfortunately they left out a few key pieces, related
more to general information, such as what CUI files
are loaded into a given installation.
So, it must be done manually (look in registry for the
name of the main and enterprise menus, and then
use the AutoCAD library search path to find them).
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5310255@discussion.autodesk.com...
Are you sure that it is allowed to call AutoCAD .NET assembly from standalong application? IMHO it is impossible. Exception not pointed to path (string csstring) but to AcCustomize.dll which is not found. It is needed for CustomizationSection class. Message="The specified module could not be found" - describe this situation.
