.NET
How to set current layer
3 REPLIES 3
623 Views, 3 Replies
How to set current layer to a specified layer? I mean use program complete this function.
For example there is a new layer called "myLayer", then I execute  a command, the currrent layer will be"myLayer".
Any help much appreciated.
3 REPLIES 3
Keith.Brown
The easiest way to set the current layer is to modify the CLAYER system variable.
Application.SetSystemVariable("CLAYER", "myLayer");
another way is using Database.Clayer property
you just set your specified layer's objectid to this property
in reply to: Keith.Brown
Smiley EmbarassedThanks for your help
Forma Design Contest
