Hello
I am making Customise tool for autocad which can draw tower automatically. user need to fill excel sheet. Which has all input like panel upper width ,lower width ,height. I want to draw continous all panel one by one as per the panel type user has select.
With Form1 and following code i am able to draw each thing seperately but now i want to draw a tower in single button click.
Imports System.IO
Imports Microsoft.Office.Interop
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.DatabaseServices
Public Class Form1
Dim tra_upperwidth As String = Nothing
Dim tra_lowerwidth As String = Nothing
Dim tra_height As String = Nothing
Dim FileName As String
Private Sub btnpeak_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnpeak.Click
'get current document
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
'lock document as using modeless form
Using docLock As DocumentLock = doc.LockDocument
Using tx As Transaction = db.TransactionManager.StartTransaction()
'open blocktable
Dim bt As BlockTable = tx.GetObject(db.BlockTableId, OpenMode.ForRead)
'open model space for write
Dim ms As BlockTableRecord = tx.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
'converte text value
Dim uWidth As Double = CDbl(TextBox1.Text)
Dim base As Double = CDbl(TextBox2.Text)
Dim tHeight As Double = CDbl(TextBox3.Text)
Dim pt1 As Point2d = New Point2d(0, 0)
Dim pt2 As Point2d = New Point2d(base, 0)
Dim pt3 As Point2d = New Point2d(base / 2, tHeight)
'draw traiangle
Dim tra As Polyline = New Polyline()
tra.AddVertexAt(0, pt1, 0, 0, 0)
tra.AddVertexAt(1, pt2, 0, 0, 0)
tra.AddVertexAt(2, pt3, 0, 0, 0)
tra.Closed = True
'add triangle in model space
ms.AppendEntity(tra)
tx.AddNewlyCreatedDBObject(tra, True)
tx.Commit()
End Using
End Using
End Sub
Public Sub READEXCELFILE(ByVal filePath As String)
'read excel file
Try
Dim xlApp As New Excel.Application
Dim xlWorkBook As Excel.Workbook = xlApp.Workbooks.Open(filePath)
Dim xlSheet As Excel.Worksheet = xlWorkBook.Worksheets("Sheet1")
'get all cells value
tra_upperwidth = xlSheet.Cells(1, 2).Value
tra_lowerwidth = xlSheet.Cells(2, 2).Value
tra_height = xlSheet.Cells(3, 2).Value
xlWorkBook.Close()
'quit excel application
xlApp.Quit()
'relaese excel object
ReleaseExcelObject(xlWorkBook)
ReleaseExcelObject(xlApp)
Catch ex As System.Exception
MsgBox(ex.Message)
End Try
End Sub
Public Shared Sub ReleaseExcelObject(ByVal obj As Object)
'release excel object after finishing
Try
System.Runtime.InteropServices.Marshal.ReleaseComObject(obj)
obj = Nothing
Catch ex As Autodesk.AutoCAD.Runtime.Exception
obj = Nothing
Finally
GC.Collect()
End Try
End Sub
Private Sub OpenToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles OpenToolStripMenuItem.Click
Dim OpenFileDialog As New Windows.Forms.OpenFileDialog
OpenFileDialog.InitialDirectory = My.Computer.FileSystem.SpecialDirectories.MyDocuments
OpenFileDialog.Filter = "Excel Worksheets (*.xls)|*.xls|Text File(*.txt)|*.txt|All Files (*.*)|*.*"
If (OpenFileDialog.ShowDialog(Me) = System.Windows.Forms.DialogResult.OK) Then
FileName = OpenFileDialog.FileName
End If
Try
'place the excelfile path
Dim excelFilePath = FileName
If File.Exists(excelFilePath) Then
Call READEXCELFILE(excelFilePath)
End If
TextBox1.Text = tra_upperwidth
TextBox2.Text = tra_lowerwidth
TextBox3.Text = tra_height
MsgBox(ex.Message)
End Try
End Sub
Private Sub btnLeg_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnLeg.Click
'open blocktable
Dim Xx As Double = ((base - uWidth) / 2)
' Dim pt1 As Point2d = New Point2d(0, 0)
Dim pt2 As Point2d = New Point2d(base / 2, tHeight)
Dim pt3 As Point2d = New Point2d(base, 0)
Dim pt4 As Point2d = New Point2d(base - Xx, tHeight)
Dim pt5 As Point2d = New Point2d(0 + Xx, tHeight)
'draw traiangle
tra.AddVertexAt(3, pt4, 0, 0, 0)
tra.AddVertexAt(4, pt5, 0, 0, 0)
tra.Closed = True
tx.Commit()
End Using
End Using
End Sub
Private Sub btnKpanel_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnKpanel.Click
'open blocktable
'draw traiangle
tra.AddVertexAt(5, pt1, 0, 0, 0)
tra.AddVertexAt(6, pt3, 0, 0, 0)
tra.Closed = True
tx.Commit()
End Using
End Using
End Sub
Private Sub btnXpanel_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnXpanel.Click
'open blocktable
Dim pt3 As Point2d = New Point2d(base - Xx, tHeight)
Dim pt4 As Point2d = New Point2d(0, 0)
Dim pt6 As Point2d = New Point2d(base, 0)
'draw traiangle
tra.AddVertexAt(5, pt6, 0, 0, 0)
tra.Closed = True
Dim line1 As Line = New Line(New Point3d(pt5.X, pt5.Y, 0), New Point3d(pt3.X, pt3.Y, 0))
ms.AppendEntity(line1)
tx.AddNewlyCreatedDBObject(line1, True)
tx.Commit()
End Using
End Using
End Sub
End Class
Now I want to draw Tower on draw button burt not getting idea how to draw it. Please help me.
Yupp i tried that but not working for me... As i need the last point as first point for next panel. Canyou please help me. I know There is very small thing which i am missing in my code.Waiting for reply.
please find attach drawing. Sir If i take starting point zero i can do that easily . bt now i want to draw continously by reading data row by row. and start from end point.
my current code is as follow:
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim Panel_name, Panel_type As String
Dim Panel_height, Panel_lwidth, Panel_uwidth As Double
Dim Panel_no As Integer
Panel_name = String.Empty
Panel_type = String.Empty
'open blocktable
For Each row As System.Windows.Forms.DataGridViewRow In DataGridView1.Rows
Panel_no = row.Cells(0).Value
Panel_name = row.Cells(1).Value
Panel_height = row.Cells(2).Value
Panel_uwidth = row.Cells(3).Value
Panel_lwidth = row.Cells(4).Value
Panel_type = row.Cells(5).Value
Dim Xx As Double = ((Panel_lwidth - Panel_uwidth) / 2)
Dim pt1 As Point2d
Dim pt_start As Point2d
Dim pt2 As Point2d = New Point2d(Panel_lwidth / 2, Panel_height)
Dim pt3 As Point2d = New Point2d(Panel_lwidth, 0)
Dim pt4 As Point2d = New Point2d(Panel_lwidth - Xx, Panel_height)
Dim pt5 As Point2d = New Point2d(0 + Xx, Panel_height)
pt1 = New Point2d(0, 0)
If Panel_type = "LEG" Then
tra.Closed = True
End If
If Panel_type = "K-PANEL" Then
'draw traiangle
tra.AddVertexAt(0, pt_start, 0, 0, 0)
tra.Closed = True
ElseIf Panel_type = "X-PANEL" Then
tra.AddVertexAt(1, pt4, 0, 0, 0)
tra.AddVertexAt(3, pt5, 0, 0, 0)
tra.Closed = True
End If
tx.Commit()
pt_start = pt5
Next
End Using
End Using
End Sub
Hi , below you will find some code to draw tower. I did not test but should be ok in logical point of view.
Dim htLegPanel As String = Nothing Dim uWidthLegPanel As String = Nothing Dim lWidthLegPanel As String = Nothing 'K-Panel Dim htKPanel As String = Nothing Dim uWidthKPanel As String = Nothing Dim lWidthKPanel As String = Nothing 'X-panel Dim htXPanel As String = Nothing Dim uWidthXPanel As String = Nothing Dim lWidthXPanel As String = Nothing
<CommandMethod("DT")> Public Sub DrawTraingle() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database 'add your excel file path Dim fPath As String = "C:\Users\alamzaki\Desktop\TowerInput.xls" Call READEXCELFILE(fPath) Dim base As Double = Nothing Dim ht As Double = Nothing Dim basePoint As Point2d = New Point2d(0, 0) 'Leg Triangle base = CDbl(lWidthLegPanel) ht = CDbl(htLegPanel) 'start point Dim L_pt1 As Point2d = basePoint 'mid point Dim L_pt2 As Point2d = New Point2d(((base / 2) + ht), ht) 'end point Dim L_pt3 As Point2d = New Point2d(base, 0) 'K triangle base = CDbl(lWidthKPanel) ht = CDbl(htKPanel) basePoint = L_pt2 'start point Dim K_pt1 As Point2d = New Point2d(basePoint.X - (base / 2), basePoint.Y) 'mid point Dim K_pt2 As Point2d = New Point2d(basePoint.X, basePoint.Y + ht) 'end point Dim K_pt3 As Point2d = New Point2d(basePoint.X + (base / 2), basePoint.Y) 'X triangle base = CDbl(lWidthXPanel) ht = CDbl(htXPanel) basePoint = K_pt2 Dim X_pt1 As Point2d = New Point2d(basePoint.X - (base / 2), basePoint.Y) Dim X_pt2 As Point2d = New Point2d(basePoint.X, basePoint.Y + ht) Dim X_pt3 As Point2d = New Point2d(basePoint.X + (base / 2), basePoint.Y) Using tx As Transaction = db.TransactionManager.StartTransaction() Dim bt As BlockTable = tx.GetObject(db.BlockTableId, OpenMode.ForRead) Dim ms As BlockTableRecord = tx.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite) 'draw leg Call TraingleBuild(L_pt1, L_pt2, L_pt3, False, tx, ms) 'draw k Call TraingleBuild(K_pt1, K_pt2, K_pt3, True, tx, ms) 'draw x Call TraingleBuild(X_pt1, X_pt2, X_pt3, True, tx, ms) tx.Commit() End Using End Sub Public Sub READEXCELFILE(filePath As String) 'read excel file Try Dim xlApp As New Excel.Application Dim xlWorkBook As Excel.Workbook = xlApp.Workbooks.Open(filePath) Dim xlSheet As Excel.Worksheet = xlWorkBook.Worksheets("Sheet1") 'get all cells value htLegPanel = xlSheet.Cells(2, 3).Value uWidthLegPanel = xlSheet.Cells(2, 4).Value lWidthLegPanel = xlSheet.Cells(2, 5).Value 'kpanel htKPanel = xlSheet.Cells(3, 3).Value uWidthKPanel = xlSheet.Cells(3, 4).Value lWidthKPanel = xlSheet.Cells(3, 5).Value ''xpanel htXPanel = xlSheet.Cells(4, 3).Value uWidthXPanel = xlSheet.Cells(4, 4).Value lWidthXPanel = xlSheet.Cells(4, 5).Value xlWorkBook.Close() 'quit excel application xlApp.Quit() 'relaese excel object ReleaseExcelObject(xlWorkBook) ReleaseExcelObject(xlApp) Catch ex As System.Exception MsgBox(ex.Message) End Try End Sub Public Shared Sub ReleaseExcelObject(obj As Object) 'release excel object after finishing Try System.Runtime.InteropServices.Marshal.ReleaseComObject(obj) obj = Nothing Catch ex As Autodesk.AutoCAD.Runtime.Exception obj = Nothing Finally GC.Collect() End Try End Sub Public Sub TraingleBuild(pt1 As Point2d, pt2 As Point2d, pt3 As Point2d, triangleClosed As Boolean, trans As Transaction, blkTblRec As BlockTableRecord) Dim tra As Polyline = New Polyline() tra.AddVertexAt(0, pt1, 0, 0, 0) tra.AddVertexAt(1, pt2, 0, 0, 0) tra.AddVertexAt(2, pt3, 0, 0, 0) 'for leg do not close the polyline If triangleClosed = True Then tra.Closed = True End If blkTblRec.AppendEntity(tra) trans.AddNewlyCreatedDBObject(tra, True) End Sub
HI , please find below code. I have tested this and this is working. One thing I have changed in your excel file is a syntax. In your excel file it was 'Lower width'. I have changed it as 'Lower Width'. for your information, I have created a class 'Tower'. This tower class will collect all the necessary data from excel file. I have test this code and it is working fine. Hope you will find it useful. I did not put comment on the code as it is self explanatory. but incase if you do not get anything just ask me.
<CommandMethod("TR")> Public Sub DrawTower() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim filePath As String = "C:\Users\alamzaki\Desktop\TowerInput.xls" Dim traTower As New Tower(filePath) 'MsgBox(traTower.triInfoList.Count) 'MsgBox(traTower.triInfoList.Item(0).panelHeight) Using docLock As DocumentLock = doc.LockDocument() Using tx As Transaction = db.TransactionManager.StartTransaction() Dim bt As BlockTable = tx.GetObject(db.BlockTableId, OpenMode.ForRead) Dim ms As BlockTableRecord = tx.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite) Dim basePoint As Point2d = New Point2d(traTower.triInfoList.Item(0).lowerWidth / 2, 0) For i As Integer = 0 To traTower.triInfoList.Count - 1 Dim base As Double = traTower.triInfoList.Item(i).lowerWidth Dim ht As Double = traTower.triInfoList.Item(i).panelHeight Dim point1 As Point2d = New Point2d(basePoint.X - base / 2, basePoint.Y) Dim point2 As Point2d = New Point2d(basePoint.X, basePoint.Y + ht) Dim point3 As Point2d = New Point2d(basePoint.X + base / 2, basePoint.Y) Call TraingleBuild(point1, point2, point3, tx, ms) basePoint = point2 Next tx.Commit() End Using End Using End Sub Public Sub TraingleBuild(pt1 As Point2d, pt2 As Point2d, pt3 As Point2d, trans As Transaction, blkTblRec As BlockTableRecord) Dim tra As Polyline = New Polyline() tra.AddVertexAt(0, pt1, 0, 0, 0) tra.AddVertexAt(1, pt2, 0, 0, 0) tra.AddVertexAt(2, pt3, 0, 0, 0) 'for leg do not close the polyline tra.Closed = True blkTblRec.AppendEntity(tra) trans.AddNewlyCreatedDBObject(tra, True) End Sub Public Class Tower Structure TriangleInfo Dim panelHeight As Double Dim upperWidth As Double Dim lowerWidth As Double End Structure Public triInfoList As New List(Of TriangleInfo) Sub New(excelFilePath As String) 'read excel file Try Dim xlApp As New Excel.Application Dim xlWorkBook As Excel.Workbook = xlApp.Workbooks.Open(excelFilePath) Dim xlSheet As Excel.Worksheet = xlWorkBook.Worksheets("Sheet1") Dim range As Excel.Range Dim rCnt As Integer Dim cCnt As Integer Dim Obj As Object Dim stTriangleInfo As New TriangleInfo() range = xlSheet.UsedRange For rCnt = 2 To range.Rows.Count For cCnt = 1 To range.Columns.Count Obj = CType(range.Cells(rCnt, cCnt), Excel.Range) 'MsgBox(Obj.value) If xlSheet.Cells(1, cCnt).Value = "Panel Height" Then stTriangleInfo.panelHeight = CDbl(Obj.Value) ElseIf xlSheet.Cells(1, cCnt).Value = "Upper Width" Then stTriangleInfo.upperWidth = CDbl(Obj.Value) ElseIf xlSheet.Cells(1, cCnt).Value = "Lower Width" Then stTriangleInfo.lowerWidth = CDbl(Obj.value) End If Next triInfoList.Add(stTriangleInfo) Next xlWorkBook.Close() 'quit excel application xlApp.Quit() 'relaese excel object ReleaseExcelObject(xlWorkBook) ReleaseExcelObject(xlApp) Catch ex As System.Exception MsgBox(ex.Message) End Try End Sub Private Sub ReleaseExcelObject(obj As Object) 'release excel object after finishing Try System.Runtime.InteropServices.Marshal.ReleaseComObject(obj) obj = Nothing Catch ex As Autodesk.AutoCAD.Runtime.Exception obj = Nothing Finally GC.Collect() End Try End Sub End Class
Thank you... With reference to your given code and modifications needed to draw tower my task is completed successfully. Thank you very much.
Hello mr mzakiralam,
Can you please help me. I want to assign Dtext or label to each polyline while drawing it or after drawing it. how can i do that. I know how to assign dtext to line.. but confused with polyline. Please help me. Please find the dwg attach herewith for reference.
code using to draw polyline is as below:
'open blocktable
'draw traiangle
tra.Closed = True
tx.Commit()
End Using
End Using
thank you... I had already open a new tread but didnot get any solution from last 2 days so replied here.
link to new thread is as below:
http://forums.autodesk.com/t5/NET/Assign-nomenclature-to-each-polyline/m-p/4874426
yes they are connecting polylines. with reference to your code i am able to draw complete tower.
no i want to label each line. within it.
HI,
Okay, I got your point now. As you know how to draw text for a line so it will be easier for you now. What you need to do just cast the polyline then you will be able to get all vertices of that polyline. If you get all vertex then I think your problem will be solved. Please see below code snippet which will help you to get the polyline and its vertices.
<CommandMethod("tst")> Public Sub TestPoly() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim peo As PromptEntityOptions = New PromptEntityOptions(vbLf & "Select a polyline to label it:") Dim per As PromptEntityResult = ed.GetEntity(peo) Using tx As Transaction = db.TransactionManager.StartTransaction() Dim ent As Entity = tx.GetObject(per.ObjectId, OpenMode.ForRead) If TypeOf ent Is Polyline Then Dim pl As Polyline = TryCast(ent, Polyline) Dim vn As Integer = pl.NumberOfVertices For i = 0 To vn - 2 'get adjacent vertices of a polyline Dim pt1 As Point2d = pl.GetPoint2dAt(i) Dim pt2 As Point2d = pl.GetPoint2dAt(i + 1) 'do what you need Next End If tx.Commit() End Using End Sub
