Hi
I need to create one Plugin for AutoCAD 2012. I created one plugin for AutoCAD 2007 using .NET 2.0 . I would like to know which is the correct .NET framework I should use for creating a plugin for AutoCAD 2012. For Ex. [.NET 2.0, .NET 3.5, .NET 4.0, .NET 4.5 etc] ?
If possible can I get a link to any autodesk official page detailing about the .NET frameworks ?
Regards
Dominic
Solved by norman.yuan. Go to Solution.
Technically, you can use any of the versons of .NET you listed (2.0 to 4.5).
However, if you use 4.x, make sure in acad.exe.config you have
<supportedRuntime version="v4.x"/>
in the <startup /> section.
With that said, using .NET4.5 with Acad2012 (or even Acad2013) is not recommended/not supported: after all, .NET 4.5 is released after Acad2013's release.
Autodesk's claim that AutoCAD would use latest version of .NET ends after AutoCAD 2009/.NET3.x. Since Acad2012's .NET API is built on .NET3.x (2.0 runtime, 3.x is just additional functionalities that run on top of 2.0), if you do not specify <supportedRuntime version=4.0 />, Acad2012 uses .NET2.0/3.x.
Acad2012 installation has <supportedRuntime version=4.0 /> set as default. So, basically you would target your Acad plugin development at .NET4.0. If you choose to target .NET3.x for some reasons, make sure <supportedRuntime version=4.0 /> is removed from acad.exe.config. You can use either VS2010 or VS2012.
Norman Yuan
