HI,
Is it possible to change the drawing editor background color via code?
Eric
Using COM Interop, you need:
Application.Preferences.Display.GraphicsWinModelBackgrndColor
and/or
Application.Preferences.Display.GraphicsWinLayoutBackgrndColor
-drg
is there other way to change the background, not using COM?
Actually I need to change the model background to different colors, to generate pictures used in a different application. If the pictures will have different colors(some black, some grey, etc) it would be easier to surf through them when finding the right one.
Any suggestions?
e.g.
why don't you like to use COM?
- alfred -
It is ok with COM; it is only from curiosity to know the equivalent in API
e.g.
There are several posts on this topic but no examples. I looked in the vb forum and objectarx but could not find anything I really understand. I have Option Strict On.
Why doesn't this work? bgcolor changes from 0 to 1 but the background stays black - I want it to change to red.
Dim prefs As Autodesk.AutoCAD.Interop.AcadPreferences = CType(Autodesk.AutoCAD.ApplicationServices.Application.Preferences, Autodesk.AutoCAD.Interop.AcadPreferences) Dim bgcolor As UInteger = prefs.Display.GraphicsWinModelBackgrndColor msg += "color " & bgcolor & vbLf prefs.Display.GraphicsWinModelBackgrndColor = CType(Autodesk.AutoCAD.Interop.Common.ACAD_COLOR.acRed, UInteger)
I am creating PNGs of all blocks in any dwg file. I get a list of blocks, insert them into a new drawing 1 at a time, and plot using publishtowebPNG.pc3. I want to allow the user to change the background color if they want. The PNGs will be used in other places.
I should have kept looking. This works. Don't forget to set it back to the original value.
Dim prefs As Autodesk.AutoCAD.Interop.AcadPreferences = CType(Autodesk.AutoCAD.ApplicationServices.Application.Preferences, Autodesk.AutoCAD.Interop.AcadPreferences) Dim curbg As Color = ColorTranslator.FromOle(CInt(prefs.Display.GraphicsWinModelBackgrndColor)) msg += "color " & curbg.ToString & vbLf prefs.Display.GraphicsWinModelBackgrndColor = CType(ColorTranslator.ToOle(Color.Red), UInteger)
