.NET
Call Rejected by Callee
13 REPLIES 13
Message 1 of 14
amitnkukanur
7422 Views, 13 Replies
I am in a new Project in  where i am using VB.net. More frequently i am getting message Call Rejected by Callee. I searched the Net on how to handle Call Rejected by Callee bout found in C#.net.
Any body has code in VB.net to handle Call Rejected by Callee
Regards
Amit
Senior Software Engineer
13 REPLIES 13
Message 2 of 14
Hallex
in reply to: amitnkukanur
Take a look at this article
http://through-the-interface.typepad.com/through_the_interface/2010/02/handling-com-calls-rejected-b...
~'J'~
Message 3 of 14
amitnkukanur
Hello Hallex, I referred to this part of code earlier also. But the code is in C#, i am converting this to VB.net but its not working still call rejected by callee
With Warm Regards
Amit
Message 4 of 14
Hallex
I know nothing about your code,
have you tried to compile your peroject
in Release mode, sometime it helps
~'J'~
Message 5 of 14
amitnkukanur
Ok Hallex, I will try
With Warm Regards
Amit
Message 6 of 14
amitnkukanur
Hello Hallex, I am executing the part of code which was provided by you in this link
http://forums.autodesk.com/t5/NET/Select-All/td-p/3551324
Message 7 of 14
Hallex
This code is working good on my end
And also take a look at this article:
http://msdn.microsoft.com/en-us/library/ms228772.aspx
especialy see the very last user response that was written on VB.NET
~'J'~
Message 8 of 14
amitnkukanur
in reply to: Hallex
Wow, Superb Hallex It solved my major problem. Actually my whole project is based on MultiThreading.
And i was processing hundreds of AutoCAD files in fixed time. But every time it used to get stuck in this bug. The link which you provided was really helpful and it resolved many errors. Thank you once again. Thanks a lot Hallex Smiley Happy
With Warm Regards
Amit
Message 9 of 14
Hallex
Glad to help,
Happy coding,
~'J'~
Message 10 of 14
in reply to: Hallex
I have this error on laptops often. I cannot get any permanent solution for this. Please someone help me solve this IN VB.NET. While opening documents via vb.net program i got this error, sometime while getting values also happened.I was getting irritated on this to solve.
Message 11 of 14
in reply to: Hallex
Tags (2)
Message 12 of 14
amitnkukanur
https://docs.microsoft.com/en-us/previous-versions/ms228772(v=vs.140)
This link will help you
Message 13 of 14
The Link does not work. Would you have the updated one?
Message 14 of 14
”Boost
