I am in a new Project in where i am using VB.net. More frequently i am getting message Call Rejected by Callee. I searched the Net on how to handle Call Rejected by Callee bout found in C#.net.
Any body has code in VB.net to handle Call Rejected by Callee
Regards
Amit
Solved by praveenkumarcs7. Go to Solution.
Solved by Hallex. Go to Solution.
Take a look at this article
~'J'~
Hello Hallex, I referred to this part of code earlier also. But the code is in C#, i am converting this to VB.net but its not working still call rejected by callee
With Warm Regards
Amit
I know nothing about your code,
have you tried to compile your peroject
in Release mode, sometime it helps
~'J'~
Hello Hallex, I am executing the part of code which was provided by you in this link
http://forums.autodesk.com/t5/NET/Select-All/td-p/3551324
This code is working good on my end
And also take a look at this article:
http://msdn.microsoft.com/en-us/library/ms228772.aspx
especialy see the very last user response that was written on VB.NET
~'J'~
Wow, Superb Hallex It solved my major problem. Actually my whole project is based on MultiThreading.
And i was processing hundreds of AutoCAD files in fixed time. But every time it used to get stuck in this bug. The link which you provided was really helpful and it resolved many errors. Thank you once again. Thanks a lot Hallex
With Warm Regards
Amit
Glad to help,
Happy coding,
~'J'~
I have this error on laptops often. I cannot get any permanent solution for this. Please someone help me solve this IN VB.NET. While opening documents via vb.net program i got this error, sometime while getting values also happened.I was getting irritated on this to solve.
