I could do it as below code, which is similar to VBA coding.
When you add reference, you need to browse "Autodesk.autoCAD.Interop.dll" and "Autodesk.autoCAD.Interop.Common.dll" from AutoCAD installation directory.
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Public Class frm_Main
Dim AcadApp As New Autodesk.AutoCAD.Interop.AcadApplication
Dim AcadDoc As Autodesk.AutoCAD.Interop.AcadDocument
Dim ThisDwg As String
'----Open blank drawing in C:\, Event when form load.
Private Sub frm_Main_Load(sender As Object, e As EventArgs) Handles MyBase.Load
ThisDwg = "C:\Test.dwg"
AcadDoc = AcadApp.ActiveDocument
AcadDoc.Application.Documents.Open(ThisDwg)
AcadApp.Visible = True
End Sub
'----Event for button click
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
Dim lineObj As AcadLine
Dim Point1(2) As Double
Dim Point2(2) As Double
Dim Point3(2) As Double
Dim Point4(2) As Double
Point1(0) = 0 : Point1(1) = 0
Point2(0) = 1 : Point2(1) = 1
Point3(0) = 2 : Point3(1) = 1
Point4(0) = 3 : Point4(1) = 4
lineObj = AcadDoc.ModelSpace.AddLine(Point1, Point2)
lineObj = AcadDoc.ModelSpace.AddLine(Point2, Point3)
lineObj = AcadDoc.ModelSpace.AddLine(Point3, Point4)
End Sub
End Class
