Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Internet Explorer 10 64bit
7 REPLIES 7
Message 1 of 8
bbrown
1686 Views, 7 Replies
Anyone else having problems getting IE 10 to open the ActiveX control in 64bit? IE 64bit went away, but running the 64bit .exe doesn't seem to correct this either.
7 REPLIES 7
Message 2 of 8
xiaodong_liang
in reply to: bbrown
to clarify:
1) Redistributable control of 2014 works well with IE10
2)  Integrated control of 2014 does not work with IE10
    2-1) Without installing SDK, IE10 does not load the Integrated control
    2-2) After SDK is installed, it looks IE10 can load the control and display the model. but actually it directs to
           Redistributable control, instead of Integrated control.
We have logged the problems. Sorry for this.
Message 3 of 8
bbrown
in reply to: xiaodong_liang
What are you doing to get it the Redistributable Control to work? I'm running IE10 version 10.0.9200.16576 and I cannot get it to work, where it did previously. MS has combined the 32bit and 64bit versions into one program, but it does not appear to load the 64bit ActiveX control.
Message 4 of 8
xiaodong_liang
in reply to: bbrown
This is the snapshot at my Win7 64bits + IE 10. The Redistributable Control works well. I did nothing but installed Navisworks. But in case it is of help, please install SDK and run the two exe at
C:\Program Files\Autodesk\Navisworks Manage 2014\api\COM\bin
In addition, are you also talking about ActiveX control of 2014?
Message 5 of 8
bbrown
I've been using the 2013 Redistributable Control up to this point (CLSID:286EA81C-56A1-4FE9-83B8-3BF08249EF2C) and it worked up until a few weeks ago. I will give the 2014 version a try and report back.
Message 6 of 8
bbrown
in reply to: bbrown
Installing the 2014 version does work.
Message 7 of 8
vchekalin
Hi xiaodong,
Are there any news for this issue? Have you found a way how to make work Integrated Control on IE10 or IE11 64-bit?
Victor.
Message 8 of 8
xiaodong_liang
in reply to: vchekalin
Hi Victor,
Sorry for missing your question. Actually, this is not a problem of our ActiveX control, instead, it is because of the mechanism of IE10 (64bits) running behind. By default IE10(64bits) will run a 64-bit process with a 32-bit inner page. This is why IE10 (64bits) does not load the control correctly. The behavior would apply to any ActiveX (64bits).
So I’d rather like to share some comments of my colleague which might help from other perspective:
As you are aware, Microsoft itself is trying to go away from plugin or ActiveX. For example, this article probably explain nicely about it:
http://blogs.msdn.com/b/ie/archive/2012/01/31/web-sites-and-a-plug-in-free-web.aspx
Nowadays, we have been seeing many 3D viewer using HTML5 and JavaScript. Browsers are started to support WebGL.
According to the statistics like this, there are less than 8% of IE users now:
http://www.w3schools.com/browsers/browsers_stats.asp
It is important to support the browser which are widely used as higher priority, isn't it? So, it might be a tricky adjustment how much/whether to invest for ActiveX further. If you want to use ActiveX control, you may try to build your own 64bit browser. i.e.,
use visual studio and embed an IE Web Browser control in a C# form.
Another alternative is to use Data and View API:
http://adndevblog.typepad.com/cloud_and_mobile/2015/02/view-and-data-getting-started.html
If you haven't looked at it, I strongly recommend you take a look.
Rail Community
