Can anybody help???
Does anybody know how to display the filename of a derived part using a Inventor VBA macro?
Just for test, I have created a part and called it "Part-1.ipt". I have then created a new part called "Part-2.ipt" and inserted the derived part (part-1.ipt) into it.
I need a macro that, for testing purposes only, shows the filename of the derived part that I inserted into Part-2.ipt.
Many thanks in advance!!!
Darren
Hi.
Take a look in one of my ideas in the signature. About derived parts, and if you like it vote it.
Also I have a sample. I can help you with it earliest Monday.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Public Sub GetNameDerivedPart()
Dim oApp As Application
Dim oPD As PartDocument
Dim oPCD As PartComponentDefinition
Dim oDerPart As DerivedPartComponent
Set oApp = ThisApplication
Set oPD = oApp.ActiveDocument
Set oPCD = oPD.ComponentDefinition
For Each oDerPart In oPCD.ReferenceComponents.DerivedPartComponents
MsgBox (oDerPart.Name)
Next
End Sub
