Repeat Components in Assembly Mode
 Repeat Component functionality could significantly reduce some repetitive assembly tasks.
A good use for this is when assembling fasteners or bolt connections that are assembled with an Insert.  each addtional occurrence should only require a single click, selecting the new circular edge, before imediately prompting for the next occurrences' circular edge and so on.
some assemblies have a few hundred bolted connections and fasteners.
Each new occurrence of the component already has the component references selected.  Only the assembly references for the highlited constraints need to be selected.
I wrote an API function to do this but it would be nice to have it out of the box.
22 Comments
Try using Kwiksert for fasteners in the meantime. It does exactly what you are describing.
karthur1
I own Kwiksert as well, but you have to purchase Kwiksert.  This functionality should be included in Inventor.
SteveMDennis
Status changed to: Comments Requested
Your mockup seems to look a lot like what iMates deliver. If you have iMates defined on the part being placed and free iMates in the open Assembly you can place multiple compenents using those iMates. Doesn't that workflow satisfy this at least on some level? If not can you explain why anything more is needed?
JoeBarnes4076
You dont have to stop and setup any iMates.  Imported legacy and vendor components?  Kwiksert works pretty good for fasteners.  Creo (Pro/e) has something like this and it works great.  Creo has iMate type functionality but the repeat command doesn't require any setup.
a_sima
just a simple REPLACE as in proe. Why imates, that's stupid!
It looks like a change to intuitivness and integration, rather than new functionality.  For one thing, this can be done from within the assembly environment rather than the part environment.  In addition, imates is buried in the Manage ribbon instead of the Modeling tab.  Maybe if it were over in the Modeling/Work Feature block? Having to rifle through the ribbons looking for commands is bad UI.
I suppose if you've got a shaft that you're going to be mounting in multiple ways, imates would be a clunky way of doing it as it would like to stick to imates.
I did not choose Inventor. I miss Pro/E because I AM an engineer, and want all the hard to use features. Like equation curve that will work in Cartesian instead of only parametric-which stinks.
I vote Inventor buys, bundles and simply pushes kwiksert so Inventor is at least competitive with Pro/E on some level with respect to this function.
To be fair, I tried using Imate on the fastener, and that is a bit faster. Still, repeat in Pro/E was a very good function, and was available back in 2008.
I will second everything said here. iMate works, but as with many things Inventor, is clunky to set up compared to other systems. I will also agree it works well once configured for a specific part/assembly, but legacy parts in large repositories (containing several hundred repeatable components) won't have iMates.
It's much more extensible to allow a part to be constained once, then copied with those constraints and quickly re-applied througout an assembly. iMates also don't handle cases where a part may not be consistently constrained but may be repeatable. Do look at other CAD packages to see some very slick workflows for this sort of procedure.
Thanks for the consideration behind this.
Mark_Wigan
I VOTE to integrate kwiksert and...
generally speaking, can we consider to try to add some more of this kind of 'sticky' or 'repeatable' functionality for similar functions...
drawings
I have found that the content center imates often merily and arbitrarily find a hole when you insert hardware. Then you have to go find your errant part. This would be more controllable and not require prior setup.
stuartmp
I agree this area of inventor could be improved. I to have written my own VBA to allow constraints to be copied from one item to another.
Kelly_Shuman
Easily record a temporary macro:
After highlighting a constrained set of parts...
Ctrl+Z copies parts; and learns everthing until [SPACEBAR]
Ctrl+V
1) Pastes the clipboard
2)[C] creates a constraint (Not a Circle!)
2a) Create an insert constraint
2b) Select the washer
2c) Select the bolt hole to constrain.
3) [SPACEBAR]
3a) Repeat 1)
[ESC]
Kelly_Shuman
I should have edited that previous comment to start the command with Alt+C, Ctrl+M, or something other than Ctrl+Z.
Is the API from the first Post available somewhere ?
karthur1
The thing I don't like about iMates (especially with fasteners) is that it does not allow an offset.  I thought that when the removed the CTRL+C ? CTRL+V from being active while the constraint command is enabled, they were going to add something to take the place of it.  I guess not, cause its been what 2 or 3 releases and nothing yet.
dan_szymanski
Status changed to: Gathering Support
Enclosed my try for a tool for this task.
LINK:  http://forums.autodesk.com/t5/inventor-deutsch/constrainmany-vba-tool/td-p/6610321
The code provided is provided "as is" and with all faults. I specifically disclaim any implied warranty of merchantability or fitness for a particular use. The operation of the code provided is not warranted to be uninterrupted or error free.
Walt_Jaquith
Although I'm sure they exist, I have yet to encounter any company which actually uses iMates. They sound like a good idea, but in my experience, the required setup and configuration time (not hard on the fastener, but a big hassle, requiring a fair measure of clairvoyance, on the mating part) makes their actual net gain in productivity approach zero. What's being requested here would be quick and easy to use on any circular feature (and please, don't forget slots) with no setup needed.
ethan_howardMMXXIV
Solidworks has a feature that allows the reuse or copy of a component with that component's constraints on the fly. Creo's version is called, "Repeat". I believe the closest Inventor comes to this is iMates. While IMates is a powerful tool, it would be nice to have this "on the fly" option and not have to check out and check in to the Vault, the component requiring an iMate.
Tags (1)
JoeBarnes4076
