When i import my inventor assembly into showcase, I import it with an angle constraint as a behaviour.
I renamed the angle constraint "Showcase" so that it creates a behaviour out of it by default.
It is able to create the behaviour, but it cannot function. In fact, no matter how i try to import it or change settings,
the playback controls always remain inactive. In other words, you can't click play or pause on the constraint animation.
How can i fix this?
Hello Ahogue,
I don't believe there is anything that can be done from Inventor's side, unless there is a problem with the constraint in Inventor. You will have more chances to get suggestions if you post it in the Showcase forum.
Here is one thread that talks about a similar problem:
http://forums.autodesk.com/t5/General/Named-Inventor-Constraints-not-working-as-behaviours-in-Showca...
I hope it helps.
