Inventor Styles read only after migration
Wapster
Message 1 of 26
Wapster
Could someone please explain me why I'm not able to copy Style Library Collections from one style library to another with the 2016 Style Library Manager ?
After migrating my 2015 (custom) Style Libraries, I want to add new 2016 styles (lightning, scenes and stuff) to my libraries.
After migration however, I'm not able to do anything with the styles because the migrated library is read only.
I do this every year, with every new IV version, but now it doesn't seem to work anymore.
Maybe someone has any ideas
Wap.
Replies (25)
Message 2 of 26
First thing I would do is check the folder permissions in Windows.
Message 3 of 26
blair
Check your Project File, is you Style set to Read-Write
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 4 of 26
mcgyvr
Mine too..
It seems to be because its one or more of the files are marked "read only" in Windows explorer but no matter what I did I couldn't turn that off.
Message 5 of 26
Check the folder permissions.  Are you on a network - talk to IT?
Message 6 of 26
mcgyvr
I'm working locally... (backup to network each night)..
I have gotten a "style library corrupt" error everyone in a while but it goes away and never seems to cause a problem.(so far and other than this)
I have NO problems editing styles,etc... just can't use the Style library manager..
Message 7 of 26
ChrisMitchell01
The Inventor dev team are currently investigating this problem. The only workarounds (I'm aware of) are:
manually move your prior styles xml files to your 2016 Design Data,
add the relevent sections from your xml files to the as-shipped files.
Or, if you still have 2015, you may also be able to export the custom styles to a styxml file from the Styles manager dialog & then import them in 2016 & then save to your 2016 styles library.
Hoep this helps,
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 8 of 26
Wapster
Thank you guys for your reply.
@ John, the permissions are okay. I have "played" with this a little but the problem stays.
I have given the folder with the migrated (2015) xml files the exact same permissions as the folder with the 2016 default files, which is editable in the Style Library Manager. No luck.
There are also no files marked "read only" in the folder.
@ blair, the project file is set to "read - write"
@ mcgyvr, I don't think this is the cause of the problem.
There are no files marked "read only" in the folder.
I tried it again with 2015 (from 2014 back-up) no problem.
I'm on this literally all day now and it's driving me nuts.
I really tried every possibility (cutting and pasting different folders and files) but nothing works
It's 9 pm now (on Friday, go figure) and I'm about to call it a day.
There are yellow and purple leprechauns running back and forth on top of my monitors, so it's time to stop.
I'll be back here tomorrow
Greets,
Wap
Message 9 of 26
Wapster
Hi Chris,
I'm not sure I understand your workarounds.
I'll be back on it tomorrow
Thanks for replying
Message 10 of 26
-niels-
Just want to add that i'm "suffering" from the same problem.
Used the style library manager to migrate my copy of the 2015 styles and after migrating it became "read only".
Any update on the dev team's progress?
The workaround seems tedious, so i'll try to hold off if there will be a fix soon...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 11 of 26
Guys!
Stop working locally and go use the Vault, it fixed this problem for us aswell. Too much time is wasted by going back and set it to read/write etc. We couldn't find out what to do about it, we changed to Vault and it's gone.
There might be a solution for it, but it consumes so much time, and why work locally when you can use the Vault?
Autodesk, no problem.
Mark
Message 12 of 26
Wapster
So.......
I'm a small entrepreneur and my design work I do alone.
I work on a stand-alone workstation. I therefore have no need to use Vault
I'm working with Inventor for more than 10 year now and every year I update my style libraries with the new "functions" of the new release, using the style library manager (it comes with the software and that’s it's intended use)
For a decade it work fine ( I had my libraries updated in minutes) and now, when there's a glitch in the program the solution is: switch to Vault
LOL Smiley LOL
Greetings,
Wap
Message 13 of 26
-niels-
@Wapster wrote:
So.......
LOL Smiley LOL
Greetings,
Wap
I agree, if only it was that easy to switch to Vault... i'm still trying to convince my boss.
And such a "minor" issue definitely isn't a good enough reason to switch to vault.
In that regard, @ChrisMitchell01 any news yet?
We're now using 2016, but there's still some styles i need to update and i'm waiting for either a hotfix or a notice that it will take (a lot) longer.
Niels van der Veer
The Netherlands
Message 14 of 26
mcgyvr
I have no use for Vault either.. I'm the only Engineer (INV user)..
The added time to check-in/check-out,etc.. is not worth it for me...
Message 15 of 26
ChrisMitchell01
Vault is nothing to do with the current issue of not being able to migrate custom styles...
A workaround has just been posted for the issue:
http://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticl...
Does that help ?
Chris
Chris Mitchell
Autodesk, Inc.
Message 16 of 26
-niels-
The workaround in that article looks good, I'll try it first thing next Tuesday when I'm back at work.
Thanks!
Niels van der Veer
The Netherlands
Message 17 of 26
Wapster
I just used the workaround and it works
Fantastic...... Smiley Very Happy
Thank you for solving this.
Have a nice weekend you all.
Wap.
Message 18 of 26
-niels-
Just used the workaround as well, finally copied over all the new styles and we're now using 2016 properly.
Thanks again Chris!
Niels van der Veer
The Netherlands
Message 19 of 26
jweiss1313
I can't download the xml file.  I keep getting an error that says the zip file is invalid!  This is so frustrating!
John C Weiss Jr.
CAD Manager
Follett LLC.
Message 20 of 26
ChrisMitchell01
John,
It's probably your browser trying to read the xml file instead of downloading it. Any different if you right click & use Save as ?
The only difference in the updated xml file is that the (existing) 3 is changed to a 4 so you could easily just edit your existing file so that it shows:
<?xml version="1.0"?>
<StudioLighting Version="4"/>
Hope this helps,
Chris
Chris Mitchell
Autodesk, Inc.
