Inventor Forum
View Label Default Position - Orientation
8 REPLIES 8
Message 1 of 9
rhasell
3155 Views, 8 Replies
Hi
This has troubled me for years, hopefully it is a quick fix.
Is there a way to change the standard orientation of the drawing view lables to Left?
Either in the standards or via iLogic?
NOTE: The option for orientation on my system is greyed out, I can only change the orientation after the view has been placed.
Thanks guys.
Reg
2024.2
Please Accept as a solution / Kudos
8 REPLIES 8
Message 2 of 9
t_hutns
in reply to: rhasell
Unfortunately formatting is not supported for view label in the standard settings, you can log a request for this enhancement to Idea Station. But as a workaround you can use VBA or ILogic rule to update view label alignment. Below is sample iLogic rule to change horizontal alignment of all view labels in the current drawing to the left:
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim oView As DrawingView
For Each oView In oSheet.DrawingViews
    If Not oView.Label.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextLeft Then
    End If
Next
Thank you for your input
Stanislav Hutnan
Inventor Development
Message 3 of 9
rhasell
in reply to: t_hutns
Thank you
Either way, I was hoping there was a quick fix.
Reg
2024.2
Message 4 of 9
jR0sal3s
how do you improve that code so that the label position will automatically align itself to the left most part of the view..?
Tags (1)
Message 5 of 9
schleede.dave
in reply to: jR0sal3s
I realize this is an old thread but I just discovered it today after noticing the same issue with Inventor 2016.  Am I the only one who thinks this makes 0 sense?  Why in the world would you lock out the option to change the justification of view label text in the standard?  And why hasn't this been changed/fixed in subsequent releases of the software?
Message 6 of 9
in reply to: schleede.dave
Agreed Dave, how many hours spent going through idws selecting text for editing, selecting the text, then justifying left. Trying to get things to look like existing AutoCAD dwgs.
Message 7 of 9
chrisw01a
You have to modify the text style that the default is using.
So open "styles editor" and find out what style it is using.
Then go to that text style and change what you need to.
On mine, I made a copy of the one it was using because other styles use that one as well.
If you do that, you have to go to "object defaults" and find "view / scale" label and change its text style to the one you want to use.
Hope this helps!
Now if I could just figure out what is driving the distance of the view label from the view so I could make it default closer...
Message 8 of 9
rhasell
in reply to: chrisw01a
Thanks.
I will test it in the real world, I am so entrenched in the iLogic code, so it will be a big change for me, but your solution works as well.
Reg
2024.2
Message 9 of 9
rhasell
Quick feedback.
Champion mate, after updating my template, this has made life much easier.
Thanks.
Reg
2024.2
