Hello everyone,
We recently moved from IV2012 to 2014, and we now have a remark in the hole notes from derived and scaled parts, that we can’t remove.
The unwanted remark:
** Scale factor used in derived part. Hole/Thread note values do not reflect scaled values**
Does anyone know if it’s possible to remove this remark (and if yes, how to remove it ).
It would save us quite some time, we now manually write the hole notes in these drawings.
Thanks in advance,
Niels
Solved by blair. Go to Solution.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
I came across this in a job the other week.
I found that if I recreated the hole/thread from scratch then when you used the note command that text had gone. Its a but of a work around but as long as the new hole/thread is exactly the same as the scaled one...
Thanks for the suggestion, but that's kind of what we would like to avoid.
We have some parts that will be used at a higher temperature (ca. 200 deg. C), so they will expand a bit. The position of the holes, and the total size of the part is important. That's why we scale it down a bit. The size of the hole's only changes very little, therefor we can use the hole note from the original part. The resulting part wil have hole that are a bit "too big" when the part reaches it's working temperature, which is acceptable.
Hi Niels!
Unfortunately I couldn't find anything in the style's, application options, document settings, etc., that's why I came to the forum.
The only thing that came close is: Document Setting -> Drawing -> Invalid annotations / Highlight
You can change the color of the incorrect dimensions with that option.
Niels van der Veer
The Netherlands
Thanks for the tip, I'll make a post in there tomorrow.
Don't have much hope left that the remark can be removed.
