Hi
I have a problem since I got a new license of inventor
If I create a drawing of a (sub) Assembly and then create the part list
→ Open drawing
→ Parts list
→ Click on the model/ or select from the folder
→ Ok
When I do this, the list floats under my mouse. I drag the list to the bottom corner and place it
when I have placed all the balloons, I want to sort the part list in numeric order of POS
→ double-click on list
→ sort by POS (I have already clicked all the buttons in this window, including the options under the arrows)
→apply
and then I get this
I have filtered balloon only on in this example. I already tried it without filter, but it still keeps sorting randomly.
If someone knows something about this, I would like to hear it.
Kind regards Elin
Solved by elin8F3WG. Go to Solution.
Not sure if this helps, but check if it's sorting numerically or by string:
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Niels van der Veer
The Netherlands
Niels van der Veer
The Netherlands
Hi
I found the problem
when you insert a table, you have to change a clap output menu from structure to parts only
This drop down menu was greyed out for me
This is because you have to remove all balloons first before you can insert a new table.
So the problem was that it sorted by the assembly which contained the parts
Niels van der Veer
The Netherlands
