Inventor Forum
Separate flanges
2 REPLIES 2
Zoltan78
395 Views, 2 Replies
Separate flanges
I'd like to separate Flange17 which I created at once (see attached file). Unfortunatelly, they will have different size. How can I separate them without falling the whole model apart? I tried to set EOF after Flange17, deselected one of them and I thought I simply create the other one again, then I will able to repair the model. But I can only convert the model back to sheet metal if I delete the splits that makes a lot of work wasted. I don't understand why do they remain solids even if I set EOF before splits.
Help please!
Zoltan
Software: Product Design & Manufacturing Collection
OS: Windows 10 Professional x64
CPU: Core i5-8600K
RAM: 2*8Gb
VGA: GTX 3070
2 REPLIES 2
WHolzwarth
in reply to: Zoltan78
Hi Zoltan,
once multibodies are introduced in a sheet metal part, no more sheet metal operations can be added.
I tried to solve your problem using Moveface1 at the end, but I don't know, if that's your intent.
And look at the positions of Hole4. They're cutting the flanges.
Walter
Walter Holzwarth
Zoltan78
in reply to: WHolzwarth
I use Inventor 2011, so, you can't solve the problem for me unfortunatelly, because I can't open the file you attached. I know about Hole4, but if I there's no factory solution for separating flanges, I have to redraw the whole thing again.
EDIT: however, it seems, MoveFace command saves my day! I had to do a few repair but it seems to be okay. I have to repair one split and I can create the missing flange after creating the parts resulting them sheet metal parts again. Thank you very much!
Zoltan
CPU: Core i5-8600K
RAM: 2*8Gb
VGA: GTX 3070
