Inventor Forum
Sweep, loft? "plastic bag"
5 REPLIES 5
1962 Views, 5 Replies
Greetings!
I'm looking for some fast help over here. I've searched but not found anything that can help me for this.
So, i am going to make a "plastic bag". Nothing fancy doh.
I want it to look kinda like the fast paint drawing i've made.(Blue color is where it is flat. Red color is what i dont want) I kinda know how to use the feature and can for example make the easy part i've atteched.
But I don't how to make the ends end with a flat surface like on the drawing.
And should i use loft or sweep?
Please tell me if you need more explanation.
/p
Tags (3)
5 REPLIES 5
mpatchus
You could try something along these lines.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
in reply to: mpatchus
Something like that could work. I'll give it a try thanks 🙂
Would be gr8 if it was flat on the sides aswell I forgot to add!
mpatchus
That is easily accomplished with a couple tweaks.
Inventor 2025 Beta
johnsonshiue
Hi! Here is another solution. It seems like the boundary of the bag is fixed but the shape within the boundary can vary (undetermined). The geometry can be easily created by using Boundary Patch. Let me know if more information is needed.
Thanks!
Software Test Engineer
in reply to: johnsonshiue
Thank you for helping Mpatchus!
I'll look into that Johnsonshiue! I don't belive I've used it but i'll see if i can figure it out.
And if you want, i would love if you can give me more information about it. Wouldnt hurt! 🙂
