What is the proper way to write the function- inverse tan when writing a equation in parameters?
example- ((Heigth/ Run)inverse tan)
Can you tell me how to correctly write out the function inverse tangent?
You can't mark it solved unless the solution is provided!
The inverse tangent function in Inventor parameters is "atan()"
For an overview of functions please take a look at;
Best regards.
The link is junk because autodesk changes the year that this is located under and the majority of the link is cut off. If you click it you get booted to the base help page.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
