Not sure if this is an Inventor thing or a vault thing? both are 2023 and when I am making components from a single part assembly it is having me click on "OK" for every single part! not too bad when it's a couple parts but around 1000 gets tiresome. also some people get this dialog box others do not is there a way to shut this off/turn it on?
Solved by -niels-. Go to Solution.
That's the Vault data standard window.
If you don't have a need for it, you can just unload the addin from the tools > addins window:
Or, if you want to quickly switch between loaded and unloaded state then you can use these buttons on the Vault tab:
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
thanks so much you made a lot of people happy this morning!
