Hi There,
I am new to Inventor and I ahve been trying to creat a wing rib similar to the one in the picture. I have been successful in recreating the basic shape itself, but I cannot figure out how to make the bend to the "lightening hole" (circle).
Any help would be seriously appreciated...
Solved by Chris1969. Go to Solution.
Attach the ipt file of what you have attempted so far - or at least indicate what version of Inventor you are using.
Do you need a sheet metal part that will give Flat Pattern - in that case look into Punch features.
otherwise - looks like a simple countersink and shell feature.
I am using Inventor 2014
What i am trying to do is make this model so I can flatten it out and use it for a template for cutting out a new wing rib. I will be doing this with a bunch of other ribs as well, so I really haven't saved any files thus far as I am trying to learn the workflow.
When you do save a file - attach it here for pointers.
You might go through these -
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
You could make a punch that created the countersunk hole.
It's not really very intuitive to do, but you can seach google for a tutorial.
But creating it as a solid and then "shelling" would also work.
Brgds,
Chris
