Hi there,
When I start a new drawing, the thread annotation are missing.
If I open an old drawing, it works fine.
I used the same template in previous versions, and never seen that issue before.
My problem is that I can't figure where to change it, I tried the styles editor, but as far as I can see it looks ok?
Can perhaps anyone give me a clue to get it right?
Thanks!
Brgds,
Chris
Solved by admaiora. Go to Solution.
Solved by -niels-. Go to Solution.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Hi Chris,
have you try this:
Admaiora
Ops
Anyway i remember that it happened to me, if you want that as default (and normally it is) you have to operate in the registry.
Admaiora
I don't remember the path.. just wait that i take a look,
Admaiora
Here it is.
A solution by Chris Mitchell (Thank you! )
I think it will works for you too.
Admaiora
Niels van der Veer
The Netherlands
You right Niels
the reason is that i am slow in typing post
Admaiora
I tried the reg edit as posted, and it seems to work. Thanks for posting!
However I feel it is far too deep and advanced for any common user (including me) to change such a basic and simple setting.
I really hope Autodesk is listening...
Brgds,
Chris
