Hey togehter,
I have a curved body (exteriorplate) that cuts a working plane. I want the trail/trace/line where these to things cut eachother. Im new at Inventor but already used Catia V5 for a longer time.
Im thankfull for every advise ,
Greetings Alex
Solved by blandb. Go to Solution.
Or start a new 2D sketch on your workplane and use "project cut edges"?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Depending on what exactly you have, if you start a 3D sketch and choose "Intersection Curve". You should be able to choose the surface and the plane > OK. Now you should have a curve that is the intersection of the 2 entities.
Thanks to all of you, appreciate it a lot. At the end I managed to do it with blandb´s solution. The problem was that I tried to do it in an assembly, so I created a simplified part out of my two parts that cut eachother.
Can you post a simplified example? Maybe there is another alternative for what you are trying to do. My approach was just based on a part, but if you are trying to find a common intersection of 2 parts for example, then there is another way.
Hi! I guess you would like to find the intersection between multiple parts. You can still do it within a part.
Open the assembly and edit a part in place. Go to Modify section -> expand the panel -> Copy Objects -> pick the geometry from another part -> set output = Surface -> check "Associative." Then the geometry will be linked to the edit target part. Then you can create 3D Intersection Curve within the editing part.
Many thanks!
I have an assembly with assemblies in it. So used one of these assemblies (a frame with tubes) and I made a workingplane based on this frame. Afterwards I wanted to get the intersection between this workingplane and another assembly (a exteriorcover of a car). I managed to get the intersection/trail/trace/line with a 3d-Sketch when I combined the frame and the cover to one part. For me the best solution is an intersection between these to assemblies straight in the whole assembly.
