Inventor Forum
Extract Component List
11 REPLIES 11
Message 1 of 12
GianlucaZerbo
467 Views, 11 Replies
Hi.
I have a problem with a extraction component list in Excel format.
The codes of parts with"0" as a first number, do not extract the 0, for example: if code is 05788845, Inventor extract 5788845, this is a problem for import of list in my management program, becouse it do not recognize the code.
Excel have the selection with "display 0 in cells with value 0".
Before everything worked, with Inventor 2017 do not work anymore.
There is a solution to this problem?
Thanks more.
11 REPLIES 11
Message 2 of 12
mcgyvr
in reply to: GianlucaZerbo
Make sure you have applied all updates for Inventor 2017..I believe this was fixed in a service pack..
Message 3 of 12
GianlucaZerbo
in reply to: mcgyvr
Tks for help... I have all version... but the problem still exists...
Message 4 of 12
mcgyvr
You are right
@Anonymous Johnson.. Can you look into this and provide an update on if this has been reported and if/when its going to be fixed..
Its a bug that hasn't been fixed yet I guess..
It does the same for me.. Inv 2017 R3
Message 5 of 12
inchul.lee
in reply to: mcgyvr
Hi @GianlucaZerbo and @mcgyvr,
This is a great catch. It appears that cell formatting is not working during export. We'll share an update of the investigation here.
In the meantime, you may consider a workaround of using an Excel template file.
The attached Excel file is just a blank file with its cell formatting set as 'Text'. Select it as a template.
Then, you should be able to get the correct result as below.
Inchul Lee
Message 6 of 12
GianlucaZerbo
in reply to: inchul.lee
@inchul.lee thanks for the help.
where I find these options in Excel or Inventor?
Message 7 of 12
inchul.lee
You can access it in Export Parts List window.
Inchul Lee
Message 8 of 12
GianlucaZerbo
@inchul.lee don't have the options...
look...I have Inventor 2017
Message 9 of 12
inchul.lee
It's because you're accessing it in the assembly environment. You'll need to create a parts list table in the drawing environment and export it from there.
It's a workaround at the moment and the symptom is currently under investigation.
Inchul Lee
Message 10 of 12
GianlucaZerbo
@inchul.lee...I think I know.. tks more.
Message 11 of 12
GianlucaZerbo
@inchul.lee...sorry... all works, but i have only another problem...
in this list i look only principal parts, and extract only first level.
I need extract all parts, becouse I also need to import the sublevels.
Message 12 of 12
@inchul.lee I think I found the solution yourself. Thank you
Autodesk Customer Advisory Groups
