Hi.
I have a problem with a extraction component list in Excel format.
The codes of parts with"0" as a first number, do not extract the 0, for example: if code is 05788845, Inventor extract 5788845, this is a problem for import of list in my management program, becouse it do not recognize the code.
Excel have the selection with "display 0 in cells with value 0".
Before everything worked, with Inventor 2017 do not work anymore.
There is a solution to this problem?
Thanks more.
Solved by GianlucaZerbo. Go to Solution.
Solved by inchul.lee. Go to Solution.
Make sure you have applied all updates for Inventor 2017..I believe this was fixed in a service pack..
@GianlucaZerbo wrote:
Tks for help... I have all version... but the problem still exists...
You are right
@Anonymous Johnson.. Can you look into this and provide an update on if this has been reported and if/when its going to be fixed..
Its a bug that hasn't been fixed yet I guess..
It does the same for me.. Inv 2017 R3
Hi @GianlucaZerbo and @mcgyvr,
This is a great catch. It appears that cell formatting is not working during export. We'll share an update of the investigation here.
In the meantime, you may consider a workaround of using an Excel template file.
The attached Excel file is just a blank file with its cell formatting set as 'Text'. Select it as a template.
Then, you should be able to get the correct result as below.
@inchul.lee thanks for the help.
where I find these options in Excel or Inventor?
It's because you're accessing it in the assembly environment. You'll need to create a parts list table in the drawing environment and export it from there.
It's a workaround at the moment and the symptom is currently under investigation.
@inchul.lee...sorry... all works, but i have only another problem...
in this list i look only principal parts, and extract only first level.
I need extract all parts, becouse I also need to import the sublevels.
