Anyone else find "express mode" rather buggy with design view reps/iassemblies/iparts?
I'm routinely running into parts not showing (disappearing even though browser icon says they are visible) when going back to load full or it not honoring changes like color overrides in design views,etc..
Toggling express then full again "seems" to fix it for most of the situations but some I need to close/reopen the file.
Many time I need to do full rebuild then generate the members again,etc...
I really don't feel like taking the time to pack & go and send this to Autodesk.. Just want them to take some more time working out the bugs. I'm finding them fairly easily and expect they could too.
Hi! You are on Inventor R2015. Have you installed Update 1 to R2015? If not, please install it and it should help enhance overall stability of Inventor. I have heard about the behavior you are talking about. But, it seems to happen randomly. Having the dataset may not necessarily help. Could you send me an email? I would like to follow up with you about some specifics.
Thanks!
Version is...
Build 159, Release 2015 RTM Update 1 - Date:Mon 05/12/2012
and yes it is fairly random I guess but does it quite often..
I'll send you an email..
Hi Brain,
This is not a known issue to us. I just played iAssembly a bit and noticed a weird issue, I recorded this into a video though Autodesk Sceencast Recorder and shared via this link View iAssembly_Express now. The problem is that when open the iAssembly in express mode, and change the 2nd assembly to another appearance, the 1st assembly will also overlap on the 2nd one.
I guess mine is different from you according to your description, so would you please share some video with me so that I try to reproduce it locally?
Thanks a lot!
-Lisa
Lisa,
Express mode has TONS of issues still. Even you were able to find one rather easily..
Here is a screencast I just sent to Johnson.
https://screencast.autodesk.com/Main/Details/2770c1ba-8db7-4cc2-8b9a-4fccc6a94af8
Notice a "chunk" (or piece) of my sheet metal part is missing but once I turn full mode back on it comes back.
Express mode is FULL of bugs. All sorts of issues from missing "pieces" of parts to complete parts missing to sub-assemblies missing to not handling appearances properly to not honoring view reps to blah blah blah the list goes on and on..
I've got iassemblies that I need to now generate the members twice each time I make a change because its not updating the first time..
I'm turning express mode OFF.. I'll try it again in INV 2017..
Based on the comments and video from you, we worked out one dataset using iAssembly, and some additional parts will appear in express mode when assigning the color appearance to the component, and it will work fine when going to full mode. The behavior is similar with what you saw. But there is one workaround -
1. Open the top assembly in Full Mode
2. “Rebuild All”->”Save”
3. In the “Save” dialog change save status to YES for top assembly ->”Ok”
4. Go to Express Mode>In pop up dialog click to “Yes” for updating assembly
5. Click to “Local Updates” icon ->”Save”
6. Go to Full Mode and then to Express Mode
Please have a try this workflow, and let us know whether it can be resolved. If you could provide the dataset to us, it should be better for us to have more investigation.
Your effort is really appreciated!
Yes.. OBVIOUSLY that workaround corrects the bugs.
Many thanks for the confirmation! Although this can be resolved by workaround, it has been tracked in our system for investigation.
I know this is an older topic, but is there any progress on this?
I'm using IV2016 and express mode still doesn't adhere to the representations of (sub-)assemblies, see screencast:
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
I came across an Autodesk article awhile back where there's a limitation of express mode when it comes to views, LODs, and positional representations. Only the last active (design view) representation is loaded under express mode. If you switch to another representation while in express mode, the representation will not load properly.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Could you send me @river-yijiang.cai@autodesk.com the dataset for more investigation?
