Hi all,
so Im on Inventor 2013.
I have a seat model I have imported from a customer. It comes across in a lovely gold colour. Nice but not what I want in my assy.
So the part was imported from a .stp file. Opens in Inventor in the ipt as a Composite 1 in the model structure. No individual ipt's.
So no matter what I change the colour to, the curves always stay gold colour. I would like them to be grey as per surfs.
So to change the colour. Firstly, with the Composite selected (lowest level in the structure) I have -
-cleared appearance overrides.
-using the Adjust pallet, input the RGB value for grey 128,128,128 and click OK
Now with the visual style set to Shaded with edges, I get the grey I want, but curves are gold colour still.
If I view further up the model structure to srf1 under Surface Bodies(1) and change these to 128,128,128, I still don't get changed curves.
Can anyone help please
As always, much appreciated in advance
Best
Dean
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Hi Niels,
thanks for your reply. Firstly I am only 6 weeks into Inventor, coming from many years of Catia and some Alias.
Self taught through online vids and help from this forum. Always appr
Yes it comes in as a composite under "Surface bodies" - "Srf1" - "Composite1"
From your reply Niels I have a bit more of an understanding of "what I have" i.e. surfs imported. I searched how to copy into construction environment, but really came up with nothing. Although I did find a post that had the same probs. "How to remove the yellow tan lines.
Could you explain how to copy into construction env please. I guess this is where I could convert to a solid?
I saw the answer of just visualising as "shaded" in visual style. I do need to visualise the whole model in "Shaded with edges" though.
Unfortunately the model is subject to a NDA so no sharing!
Many thanks
Dean
Niels van der Veer
The Netherlands
I made this video, showing several things like the import settings and where the "copy to construction" can be found.
But after uploading i realized, i have my application options set to make edges black.
I think this might be what you're experiencing, because when i set it to use the document settings i got edges that were the original yellow of the surfaces.
If this is what you are seeing, then i must say that i don't immediately know of a way to change the color of the actual surface edges.
(other than setting the model edges to "one color")
I think it would be best to try and make a proper solid out of your model, if at all possible.
That way you don't have to worry about surface edges.
Niels van der Veer
The Netherlands
Niels,
you are a star mate. Thanks for your time and the movie.
I did not import the stp the way you showed, just did an open. When I right click on the Composite I do not get the copy to construction option! Must again be due to the way I opened the file. I will use your route in future.
However In tools-document-settings-display apperance, setting model edges to one colour (and choosing the 128,128,128 grey as acustom colour) did the trick.
Cheers my friend and all the best
Dean
Niels van der Veer
The Netherlands
