so I just got auto cad 2022 and I opened it up only to get a white box and an app that's completely unresponsive, Please help.
Solved by paullimapa. Go to Solution.
doing a search on-line gets lots of possible solutions to try:
Autocad LT on launch is showing a blank white box. - Autodesk Community - AutoCAD LT
I've done all the plausible solutions that were on the autocad forum with no luck. i even went as far as trying to mess with the file name to not include hardware, i have the most to update graphics card on my computer, i've tried to downgrade the year of autocad i'm using. I'm on the verge of panicking since I'm behind 3 labs since this isn't working
Have you tried downloading and installing 2023 or 2024?
How about contacting Autodesk
yep, my case # is 20851307, also i'm using the educational version so i'm not able to use the live chat feature 😞
And did you try installing 2023 or 2024?
Have you tried logging onto windows as another administrator user and then run AutoCAD
Open Task Manager. Click the arrow in front of AutoCAD and make a screenshot of the processes related to AutoCAD so we can see what's going on.
