First, i'm french and i don't speak english very well, so apologize me about this !
Je suis dessinateur en bureau d'études structure spécialisé dans le béton armé et je travaille sur Revit 2014. J'ai voulu l'installer sur mon ordinateur personnel pour apprendre à mieux m'en servir. Mon ordinateur à la configuration suivante :
- Mac Book Pro
- 2.6 GHz intel core i7 (turbo boost jusqu'à 3.8 GHz)
- 16 Go de mémoire vive
- Disque SSD 500 Go
- Nvidia GeForce GT 750M de 2 Go
Quand je l'installe sur ma partition windows 8.1 que j'ai créé avec Bootcamp (logiciel de virtualisation), tout fonctionne. Aucun problème lors de l'installation.
Mais lorsque que je charge un projet, Revit ne répond plus et deux icones en bas de la fenêtre clignotent très rapidement.
Existe-t-il une solution à ce problème ?
Merci
Translation :
I'm draughtsman in research department structure specialized in the reinforced concrete and I work on Revit 2014. I wanted to install it on my personal computer to learn more about this software. My computer has got the following configuration :
- Mac Book Pro with Windows 8.1
- 2.6 GHz Intel core i7 (turbo boost up to 3.8 GHz)
- 16 Go memory
- Disc SSD 500 Go
- Nvidia GeForce GT 750M - 2 Go
When I install it on my Windows 8.1 partition, which I created with Bootcamp (virtualisation software developed by Apple), all work perfectly. No problem at the time of the installation. But when I load a project, Revit again doesn't answer more, and two icons in the bottom of the window flicker very quickly. Does there exist a solution for this problem?
Thank you
My graphic card hasn't tested yet by Autodesk because I've got a laptop. So my graphic card is made for laptops. But she's still powerfull.
Nvidia GeForce 750m
I'm having exactly the same problem.
Same Macbook Pro and windows 8.1 via Bootcamp.
Has anyone figured a solution?
Regards
Daniel Queiroz
Problem solved!
For Revit 2014 to work properly on Windows 8.1 in a Macbook Pro Retina display you just need to personalize the display settings to 150%, like selmat23 described on this other post
